Second day of Fibre and down to 5mb from 37mb
- Re: Second day of Fibre and down to 5mb from 37mb
06-03-2013 7:14 PM
Quote from: Max Well this is annoying, just disconnected everything (probably a bad idea anyway) but no better..
Quote from: Edzashed Well it could be this bad have been like this seven weeks now on FTTC..
What gateway are you currently on?
06-03-2013 7:20 PM
This is located in Telehouse North.
I've had a drop of at least 35mb on this one and Im getting sick of moving gateways all night long..
06-03-2013 7:34 PM
This is located in City Lifeline House.
06-03-2013 8:00 PM
Quote from: englishrick ptn-ag02
Are you speeds low at the moment or OK? I've got a test to do tonight to try and rule in/out something and I need to find someone that is seeing a problem where they normally disconnect/reconnect and it goes fine and see if the test I'm going to do fixes it or not.
Plusnet Technology
06-03-2013 8:00 PM
Quote from: Max You are currently connected to gateway pcl-ag07.
Having a look if I can see anything obvious wrong.
Plusnet Technology
06-03-2013 8:08 PM
Quote from: dave
Its gone back up 20mb
06-03-2013 8:10 PM
Plusnet Technology
06-03-2013 8:16 PM
Same goes to anyone else that is on pcl-ag07 or pcl-ag08 and seeing any problems that started around 7pm tonight.
Plusnet Technology
07-03-2013 6:53 PM
dick:quote
07-03-2013 7:20 PM
dick:quote
07-03-2013 7:33 PM
Quote from: englishrick I tried tonight again to get it up again by turning disconnecting router and turning off modem for an hour but it has gone down a touch again.....
Better to do it during daylight hours. DSL is susceptible to greater noise from AM radio transmissions after dusk, so you're more likely to get a better sync rate during the day.
07-03-2013 7:37 PM
dick:quote
07-03-2013 7:53 PM
07-03-2013 7:58 PM
07-03-2013 8:06 PM
