SNRM Reset please
- SNRM Reset please
- « Previous
- 1
- 2
- Next »
Re: SNRM Reset please
12-06-2013 4:26 PM
No problem.....if we both get a solution
Message 16 of 21
(406 Views)
12-06-2013 4:35 PM
Hi baldrick,
It should uplift itself, though if it takes more than a couple of days let us know and we'll put an SNR reset through for you.
Message 17 of 21
(406 Views)
16-06-2013 4:00 PM
My stats now are:
Modulation : G.Dmt
Annex Mode : Annex A/L
Line State : up
Lan Tx : 810197
Lan Rx : 401048
ADSL Tx : 290009
ADSL Rx : 4031241
CRC Down : 2
CRC Up : 8
FEC Down : 0
FEC Up : 0
HEC Down : 29
HEC Up : 1
SNR Up : 25.0
SNR Down : 11.5
Line Attenuation Up : 4.0
Line Attenuation Down : 10.5
Data Rate Up : 448
Data Rate Down : 8128
Results from BTW Speedtester are :
Download speedachieved during the test was - 6.26 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
Can you please try a SNR reset if that is what is needed to remove the 6.5Mbps IP Profile limit.
Thanks.
Modulation : G.Dmt
Line State : up
Lan Tx : 810197
Lan Rx : 401048
ADSL Tx : 290009
ADSL Rx : 4031241
CRC Down : 2
CRC Up : 8
FEC Down : 0
FEC Up : 0
HEC Down : 29
HEC Up : 1
SNR Up : 25.0
SNR Down : 11.5
Data Rate Up : 448
Thanks.
Message 18 of 21
(406 Views)
17-06-2013 11:49 AM
Message 19 of 21
(406 Views)
18-06-2013 3:05 PM
IP Profile now 7.15Mbps. Thanks for the support from all the PN team - it is much appreciated.
Message 20 of 21
(406 Views)
19-06-2013 10:24 AM
Message 21 of 21
(406 Views)
- « Previous
- 1
- 2
- Next »
