SNR just jumped from 2db to 14db!
- Re: SNR just jumped from 2db to 14db!
23-03-2012 1:24 PM
For a while now our internet connection has been very poor and intermittent (usually around 30 minutes is a very good amount of time to stay connected).
I checked and regularly the SNR has been around 2db. I checked last weekend and this had jumped to around 14db and the connection had been up for over 8 days (which is a miracle!), and downloads at around 1Mbit (previous best was 512kbit).
Is it worth at this point getting an SNR reset to push for a better sync rate or not be tempting fate too much ??!
23-03-2012 2:43 PM
23-03-2012 3:51 PM
23-03-2012 4:59 PM
26-03-2012 10:17 AM
I'll grab the full stats when next near the router.
Always connect wired for the computer. It has been rock solid for almost 2 weeks now, but if you look at the connections before that you'll see lots of disconnections every few minutes. I was just wondering what improved?
Would it better to stay at the 15dB noise margin or try and get it reset to push for a better speed?
26-03-2012 11:26 AM
26-03-2012 4:25 PM
Can you tell me if you're using any extension cables/sockets? Do you have a test socket you can plug into? If you were in the test socket, I would be happier about a reset.
Jojo
26-03-2012 8:26 PM
26-03-2012 11:33 PM
No extension cables/sockets. Its a dedicated line for broadband and has the openreach filtered faceplace (in fact most of the time there isn't even a phone connected as its not used for calls).
jelv - thats what I'm a bit worried about, maybe I should stick to the 1mb sync and 15db target?
27-03-2012 1:22 PM
There should be a test socket behind the filtered faceplate. It's not unheard of for filtered faceplates to cause issues. If I was to reset the SNR (and this is to jelv too) I would set it to 6dB, although it's still liable to fluctuations from the target.
Jojo
