SNR Reset
- Re: SNR Reset
- « Previous
- Next »
Re: SNR Reset
24-04-2013 3:20 PM
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :4.7 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 3.5 Mbps
The line speed showing on PN is at 4.5Mbps
I will post the results again at 10ish tonight.
Cheers
Re: SNR Reset
24-04-2013 3:27 PM
Your profile at this sync speed should be 4Mbps, but as this is 20CN it will take DLM around 4 days from whenever you synced at 4544 or higher.
Re: SNR Reset
24-04-2013 10:26 PM
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4.704
Data Transferred (Sent/Received) [MB/MB]: 23,78 / 310,81
Output Power (Up/Down) [dBm]: 12,1 / 19,9
Line Attenuation (Up/Down) [dB]: 30,5 / 47,0
SN Margin (Up/Down) [dB]: 21,0 / 8,5
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 42 / -
FEC Errors (Up/Down): 1 / 80.283
CRC Errors (Up/Down): 2 / 69
HEC Errors (Up/Down): - / 539
Download speedachieved during the test was - 3.38 Mbps
Re: SNR Reset
24-04-2013 10:46 PM
Those attenuation figures still bug me a bit though.
Re: SNR Reset
26-04-2013 9:14 AM
Re: SNR Reset
27-04-2013 10:57 AM
Re: SNR Reset
27-04-2013 10:59 AM
Re: SNR Reset
27-04-2013 12:00 PM
Data Transferred (Sent/Received) [MB/MB]: 62,13 / 793,48
SN Margin (Up/Down) [dB]: 21,0 / 8,7
Error Seconds (Local/Remote): 84 / -
FEC Errors (Up/Down): 2 / 178.292
CRC Errors (Up/Down): 3 / 161
HEC Errors (Up/Down): - / 1.096
Re: SNR Reset
27-04-2013 12:17 PM
Re: SNR Reset
29-04-2013 11:24 AM
Sorry it didn't take effect - I've just placed another one for you, please let us know if you notice any difference - should be happening early this afternoon or so.
Re: SNR Reset
31-05-2013 3:26 PM
The sync speed is now at 5300kbps for over a week but the download speed is 3700kbps is there any chance someone could give it a nudge please?
Graham
Re: SNR Reset
31-05-2013 4:17 PM
The Upstream SNRM is fine, that's precisely the sort of value one would expect on 20CN 448kbps US sync speed.
Re: SNR Reset
31-05-2013 5:21 PM
- « Previous
- Next »
