SNR Reset please
- SNR Reset please
Re: SNR Reset please
31-12-2013 4:21 PM
Quote from: Chris If you're going to reboot the router it's best to do so during daylight hours, there's generally less 'noise' around.
I do find it between 1:30pm and 2:00pm are the best time to reboot the router
03-01-2014 8:55 PM
03-01-2014 9:20 PM
03-01-2014 9:28 PM
The weather won't be helping things either...particularly if you have overhead pylon telephone cabling.
04-01-2014 11:11 AM
04-01-2014 2:36 PM
Only thing it could be is the line outside or something on the pole or further along.
Beginning to despair of anything ever being decent again.
04-01-2014 3:30 PM
04-01-2014 4:08 PM
My son doesn't want to go back to the 582 as he is finally able to use his Xbox over the wifi.
Homeplugs do not work as we live in an old house, we have tried them.
My wife does not wish me to drill holes through 3 thick walls to route Ethernet cable upstairs to his room.
Would just like to be able to use the internet etc without all the hassle I am feeling at the moment. NEVER had this with BE!
PS Line is quiet at the moment Also is it possible my PN and BT profiles are set differently?
04-01-2014 5:36 PM
You connect the TP-Link to an ethernet port on your 528 router with an ethernet cable. You would need to change the router type to Access Point in the admin settings page.
It's a good idea by jelv as it will allow you to monitor your noise margin, whilst maintaining the good wireless coverage with your TP-Link router.
04-01-2014 5:56 PM
04-01-2014 6:37 PM
04-01-2014 7:05 PM
04-01-2014 7:29 PM
04-01-2014 9:10 PM
Good start to 2014 NOT
05-01-2014 10:16 AM
I assume I just connect one ethernet cable between 582 and TP-Link?
Quote from: AndyH You connect the TP-Link to an ethernet port on your 528 router with an ethernet cable. You would need to change the router type to Access Point in the admin settings page.
Is this the admin settings of the TP-Link?
