SLow adsl
Fixes: 371
Re: SLow adsl
Hopefully, a new stats report may help.
Fixes: 241
Re: SLow adsl
That’s the router’s activity log shown it doing what it should do. It would be helpful to see the stats page again … but remember to redact personal information.
Georg
Re: SLow adsl
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ81820617
3. Firmware version: Software version 4.7.5.1.83.8.289.1.3 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 1 days, 04:44:25
6. Data rate: 448 / 8096
7. Maximum data rate: 1296 / 11584
8. Noise margin: 26.0 / 20.2
9. Line attenuation: 10.0 / 14.1
10. Signal attenuation: 10.0 / 14.9
11. Data sent/received: 426.6 MB / 12.1 GB
12. Broadband username:
13. 2.4 GHz Wireless network/SSID: PLUSNET-5X2N
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-5X2N
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 08:d5:9d:93:f2:d8
23. VPI/VCI: 0 / 38
24. Modulation: G.992.1 Annex A
25. Latency type: Interleaved
26. Software variant: AA
27. Boot loader: 1.0.0
This is the latest of what is going on with the router.
Fixes: 371
Re: SLow adsl
Try rebooting the router, and then rechecking that data.
Georg
Re: SLow adsl
Looking at the stats the max from exchange is 8mb on Adsl_G.dmt. I should be on Adsl2+ and not Adsl_G.dmt. So it looks like I will have to contact Plusnet to alter this. I was getting up to 22mb with old provider on Adsl2+ then changed to Plusnet and now down to 7.4mb on same line and routing ect.
Fixes: 371
Re: SLow adsl
Have you tried rebooting your router? - @willcutforth said yesterday he had put you on ADSL2+, but you will have to reboot to pick this up.
RealAleMadrid
Fixes: 68
Re: SLow adsl
@jab1  It's not clear what @willcutforth did. I would be surprised if Plusnet can instantly change the product type to ADSL2+ it may need an order raising with BT wholesale, which as it's the weekend nothing will happen until Monday and it may then take some time for it to be actioned.
@Georg  Worth trying a router reboot  but I suspect the change to ADSL2+ has not happened yet.☹️
Fixes: 371
Re: SLow adsl
Never thought of it being the weekend, @RealAleMadrid  - ta for the reminder. 😀
Georg
Re: SLow adsl
Thanks anyway, I have rebooted but still on Adsl_G.dmt and max 8mb leaving the exchange, worth a try , hope that Bt switches me to the other node soon as at the w/e they are on auto pilot.
many thanks all
