Routing issue!
pvmb
Champion
Fixes: 15
Routing issue!
Here we go again...
Shian Housing Association
https://www.shian.org.uk/
"This page isn't working at the momentwww.shian.org.uk redirected you too many times.
To fix this issue, try clearing your cookies.
ERR_TOO_MANY_REDIRECTS"
What is wrong with Plusnet's Network systems?
10 REPLIES 10
corringham
Seasoned Champion
Fixes: 23
Re: Routing issue!
This isn't a Plusnet problem - it appears to be an issue with the destination site, or possibly a reverse proxy that serves that site.
I don't use Plusnet and see the same issue.
pvmb
Champion
Fixes: 15
Re: Routing issue!
OK. Thanks for that.
I just found that tracert resolves OK to thundercloud.uk
Penny
Fixes: 9
Re: Routing issue!
... I just looked it up at Domain Diagnosis - https://www.domaindiagnosis.com/index.php?query=www.shian.org.uk
There's some very odd stuff on that page.  I don't understand a great deal of it but there seem to be a lot of arrays / redirects.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
pvmb
Champion
Fixes: 15
Re: Routing issue!
...very odd stuff indeed.
WHOIS
"Error for "www.shian.org.uk".
This domain cannot be registered because it contravenes the Nominet UK
naming rules. The reason is:
the domain name contains too many parts."
Uh?
Is Shian.org.uk down?
https://downforeveryoneorjustme.com/shian.org.uk
"It's just you. shian.org.uk is up.
Last updated: Nov 27, 2024, 5:25 PM (14 seconds ago)"
This is a London based housing association. I wasn't having these problems a couple of weeks or so ago.
Re: Routing issue!
17:35
It works for me
EDIT I did not at the time you first posted or using Vodafone mobile data, also note @corringham post
pvmb
Champion
Fixes: 15
Re: Routing issue!
...OK. Then it IS a DNS or routing issue.
Fixes: 387
Re: Routing issue!
Works OK for me - but I'm not on a BT connectiom, rather Zen, and they have their own routing.
RealAleMadrid
Fixes: 68
Re: Routing issue!
@pvmb  Working now for me on a Plusnet connection. It wasn't when you first posted so appears to have been a temporary glitch.
pvmb
Champion
Fixes: 15
Re: Routing issue!
OK!
Seems to be a Cloudflare DNS issue. I originally switched to Cloudflare because of original routing issues using Plusnet DNS, as mentioned previously on this site. Now had to switch back to Default (Plusnet) seemingly because of Cloudflare DNS issues...
paul_blitz
Fixes: 4
Re: Routing issue!
No use looking up www.shian.org.uk if you want a more 'general' report, that just gives the single "A" Record for the website. For anything more, you just want to look at "shian.org.uk" then you get to see all the details... The Nominet bit also is correct then!
