Router won’t connect to internet after circuit breaker tripped.
- Router won’t connect to internet after circuit bre...
07-09-2018 7:27 PM
Our kettle blew and tripped the circuit breaker. The phone and router are on the same circuit. When power was restored the router started but shows no light connected to the internet. The phone works fine. We have restarted the router and then reset it and still no internet. Help?!
Re: Router won’t connect to internet after circuit breaker tripped.
07-09-2018 7:36 PM - edited 07-09-2018 7:41 PM
Most prob Fried m8, they are cheap afterall..
{edit] Remember next time when on the webz, don't make a Cuppa...
08-09-2018 5:50 PM
If the router is left switched on all the time as recommended, it wouldn't matter if you are "on the webz". ![]()
It's might be worth investing in a surge protected extension lead for the router.
10-09-2018 10:21 AM
HI @Bink
I can see that you're now back online, which is great news.
If there's anything else you need going forward, just drop us a line.
Best wishes,
Dave
P.S - Mine's a coffee, milk, two sugars. Cheers.
