Router recomendations
- Router recomendations
02-07-2012 6:35 PM
My friend wants to sign up for plusnet but he want's to check his router/modem options first. Currently Plusnet supplies the "Technicolor 582n" but it's cheaper to get off of amazon (if you don't anticipate being a member for a year) but is very poorly rated anyway. He was wondering what other compatible router-modem combos there were that people had purchased recently and would recommend as being reliable, and hopefully on the budget end of the spectrum.
Thanks from both of us in advance
Leanne
Leanne
Message 1 of 4
(916 Views)
3 REPLIES 3
Re: Router recomendations
02-07-2012 7:15 PM
Does he need wireless? If not right at the low end of budget: http://www.ebay.co.uk/itm/Netgear-DG834-ADSL-Firewall-Router-/271008252468?pt=UK_In_Car_Technology&h... and there's wireless ones for very little more.
Message 2 of 4
(361 Views)
06-07-2012 2:24 PM
I'm the aforementioned friend. I've signed up for plusnet so am able to post here.
I was ideally looking for something that someone could recommend from personal experience as I've had a router in the past that was absolutely dire even with all the appropriate port-forwarding set up, and others that have been fine. Wireless would definitely be nice (probably essential), compatible with ADSL2+ would be good too, and obviously (alike to your suggested one) I'm looking for an ADSL/broadband modem+router combo not just a straight up router.
Any suggestions? I'm thinking of getting a Netgear dg834gt if I can find a refurbished/new one that's not too expensive and had the appropriate AC adaptor and whatnot.
Many thanks,
~B
Many thanks,
~B
Message 3 of 4
(361 Views)
06-07-2012 2:43 PM
Seems a good idea
I am very happy with the DG834G v4 which uses the same chipset
Message 4 of 4
(361 Views)
