Router password
- Re: Router password
Router password
08-06-2011 7:06 PM
Hi all,
Help needed. I need to reset my password for the router as I have completely forgot it.
How do I do it?
How do I do it?
Message 1 of 3
(4,389 Views)
2 REPLIES 2
Re: Router password
08-06-2011 11:09 PM
Resetting your router to default settings will reset the password to its default value. Most routers have a button recessed inside a pinhole to reset. Poke this with a pin or unwind a paper-clip and use that.
Message 2 of 3
(521 Views)
Re: Router password
08-06-2011 11:22 PM
ReedRichards is right; if you are using a Plusnet supplied Thomson router there should be a reset hole between the power cable and the first two Ethernet lights on the back of the router. Push a pin in there (pen won't work, believe me I've tried several times) and hold till the light goes red. Release & wait for a few moments whilst the five lights flash and reset to green.
If you are using a 3rd party router, you should be able to find the information on their websites or with the end user manual that came with the router.
Alternatively, a Plusnet supplied router will have the password written on the bottom of the router; it is the routers serial number & should begin with CP and several numbers.
Remember that the serial number is case sensitive so make sure you hit the caps lock key before typing it in.
Message 3 of 3
(521 Views)
