Router keep dropping connection
- Router keep dropping connection
24-11-2010 12:48 AM
I am using a Tomson TG585 router every so often it drops the connection, all the lights go off and the router appears to restart, this has been happening for a while at random times and was just wondering if there was any reason for this or anything i can do to stop it from happening?
Message 1 of 2
(515 Views)
1 REPLY 1
Re: Router keep dropping connection
24-11-2010 8:54 AM
Sounds like you have a faulty router if all the lights go out and it reboots (or power supply) . Have you got another router to try or can you borrow one?
Message 2 of 2
(261 Views)
