Router flashing red
stephen6
Router flashing red
My router has started flashing red this morning, so getting no internet. I did a reboot and a factory reset but neither worked. Did the text service and they confirmed there is an incident in my local area. However, it has been more than 30 mins and no further calls or texts.
The expected fix is 22/12/2023 by 5pm. So nearly 3 days at worst case scenario. I work from home so need the broadband in order to do my job. So I am unable to work now and no idea what else to do. I also don't have enough data to use a personal hotspot on my phone.
2 REPLIES 2
Fixes: 580
Re: Router flashing red
Many people consider broadband as almost an essential service these days, unfortunately that doesn't include Openreach!
That's OR's normal expected repair time, it may well be fixed before that but it's not a guaranteed fix time I'm afraid.
You should get compensation if its not fixed within the expected time, unless its an MSO (Major service outage) but if you need broadband for work then you probably ought to think about some backup plan. If you've got decent 4g or 5g coverage then think about a sim plan where you could add extra data allowance instantly and use a phone as a hotspot.
MatthewWheeler
Fixes: 503
Hi @stephen6
I'm sorry to hear this happened.
It looks like things came back on around 12:20pm yesterday and my tests aren't showing a issue anymore.
Is all working okay now?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
