Router connection dropouts
82sg
I’ve been with Plusnet for a couple of years now and never really had any problems with connectivity until recently.  Perhaps about a month or so ago, the router started to reset its connection every few hours. It got so bad that I logged a fault and Plusnet organised for an Openreach engineer to have a look.  They let me know that they repaired some cabling at the cabinet, and it has made a difference in that the resets have reduced in frequency to maybe 1 or 2 a day, but this is still a nuisance.  The remote tests apparently don’t show any problems and I’ve tried all the usual steps of reboots, checking the cabling from the master socket to the router etc.
I’ve also now started to notice that the reported downstream speed will occasionally drop from 40mbps, which is what it usually was previously, to around 30mbps.
I’m wondering if there’s anything else I should be trying? If anybody has any suggestions I’d be very grateful.
Thanks.
37 REPLIES 37
Fixes: 392
Re: Router connection dropouts
@82sg As PN say there 'isn't a problem', then we need to do a bit of self-investigation. I assume you are on FTTC, using a Hub2?  Do you still have a phone service?
82sg
Hi John, thanks for the reply. I don’t have a phone service anymore.
Fixes: 392
OK - not a problem.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'- if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Please DO NOT reboot/restart the router.
Fixes: 392
@82sg In addition to the above - when you 'lose connection' does  your Hub light change colour?
Assuming you have a Hub2, can you please attach the error log to a post - navigate to the page in the screen shot below, and click the 'export' button.
82sg
Hi John,
Thanks for the suggestions, unfortunately I can’t reach the BT test site, it appears to be down. The hub light changes to orange I believe. I’ve attached the error log as requested.
Many thanks,
Gary.
Fixes: 392
@82sg Thanks for the event log. From that, I think it is safe to say you are having too many DSL drops for it to be claimed you are 'running normally'. Personally, I would go back to PN and ask them to carry out some more checks. I appreciate you have said previously that you have done reboots/checked cabling etc, which obviously will give rise to some of the drops, but very recent behaviour still suggests there is something not quite right.
Before you do go back to PN, though, can you post your 'Technical Log - Information' screen, so we can see your connection status -  obscure your user name in it.
outcast
Aspiring Champion
Fixes: 19
@jab1  is it worth removing the above lines from your cut and paste text, now that the BTW test is permanently retired ?
In my opinion, if you wanted to quote a alternative test, my suggestion would be https://www.waveform.com/tools/bufferbloat as the included latency test is a great indicator to show whether the tested connection has upload bandwidth problems, or is running some unexpected cloud backup or torrent sharing - which most other speed testers don't reveal.
Fixes: 392
Good point @outcast - I shall amend my script accordingly at some point today - although the number of times it needs quoting is reducing as more and more move to FTTP.
@outcast
Bufferboat tests on a Hub Two is not advised as the reported results would be misleading as the result is always poor with no option on the Hub to improve anything
Fixes: 392
I was thinking about that @Dan_the_Van . For speed testing purposes, I shall probably substitute the Ookla test.
outcast
Aspiring Champion
Fixes: 19
@jab1  yes I agree with your FTTP point,  however I've twice had to walk through people with newly upgraded 300Mb FTTP using NON-Plusnet routers because their upload path was showing spikes of excessive latency, and used the waveform test to help them apply QoS and optimise their latency and bandwidth with their third party router.
Using the waveform test  early in diagnosing any line problems, seeing a "Bufferbloat Grade" of "F" is an immediate red flag !
The waveform result is also a good indicator to distinguish whether we're looking at an ADSL line, or a very slow FTTC/SoGEA problem - especially when the customer doesn't understand the terminology.
And finally, as more people migrate their Plusnet landline phone numbers to VoIP in 2025 as the PSTN switch off progresses, I think we're going to see an increase in problems here with people reporting issues with poor VoIP call quality or call dropouts, as the Plusnet Hub2 doesn't appear to support the prioritisation of VoIP packets on slow DSL lines - so again the waveform bufferbloat score, or the upload active latency result, is a quick thing to check in this situation.
IF you choose to take my suggestion of using the waveform test in your cut and paste text, can you make your instructions clear that the customer needs to paste the result URL in their forum reply, rather than quoting individual speed or latency numbers, because using the URL ensures that we see a complete picture of what is going on.
Suggested steps -
  1. Ensure that the internet connection isn't being used for anything else, such as downloading or streaming etc.
  2. Browse to the test at https://www.waveform.com/tools/bufferbloat
  3. Click on the [Start Test] button, and let the test run.
  4. When the test completes, find "Share Your Results:" at the bottom of the results panel.
  5. On that same line, click on the [Copy] button to grab the test result URL.
  6. In the Plusnet forum reply editor, click on the 'Insert/edit link' icon (the chain symbol at the top)
  7. In the pop-up 'Insert Link' window, paste the test result URL in to the 'URL' box at the top, then click on [Ok] button.
  8. Finally, click on the forum editor's [Post] button.
outcast
Aspiring Champion
Fixes: 19
For me,  the Ookla test consistently gives me random and misleading results, because for me being near London, the Ookla's algorithm for automatically choosing which test server to use, more often than not will pick one of several London servers with low latency but with insufficient bandwidth to give meaningful results.  Therefore Ookla is the test I avoid using.
If you are choosing to do just a simple speed test, then this test is simple and accurate - https://embeddable-speedtest.samknows.com/ .
I also use the ThinkBroadband test - https://www.thinkbroadband.com/speedtest , as that seems accurate, and the resulting graphs can be useful.
Anyway I'm not trying to tell anyone what to do, I'm just suggesting what I would do.
@jab1  keep up the good work ! 😎
Fixes: 392
Fair enough, @outcast . We obviously have different approaches. For me, I like to start off simple, as very many of the original posters, in my experience, are not always that tech savvy, so getting them to do simple things first makes life easier. If we need to get more involved, then I will do so, but you have to recognise that most home users who come on here with problems are easier to help if you keep the replies as simple as possible.
@outcast
For what it is worth performing a buffer bloat test always gives me a result of D on a good day I might get a C.
Over diagnosis of an issue in the first instance should be avoided as it can add a layer of complication that's not required.
