Router Keeps Resetting !
Fixes: 585
Re: Router Keeps Resetting !
With everything apart from the xDSL uptime looking perfect.
the xDSL uptime is only short because the Hub is rebooting !!
It's a hardware fault.
Fixes: 387
OK.👍
hungryhorse11
I`ve reset the Hub back to its original default factory settings via Plusnet Hub Two Manager, and it seems of calmed down now. Its been ok for the last 4hours now 🤞
The Hub hasn't been right for the last few months with it resetting itself at least once nearly every day, but today it reset itself 4 times....
Thanks everyone for all your help and advice 👍
