Route flashing
RyanL987
Route flashing
Currently have no internet with the router flashing red.
I have reset the box and unplugged it also but it hasn't worked.
What else should I do now?
7 REPLIES 7
Fixes: 389
Re: Route flashing
Is your phone line clear? - Dial 17070 and select option 2 -  there should be no noise apart from the regular 'Quiet Line Test' message. Have you recently suffered from thunder/lightening - which may have damaged overhead cables?
RyanL987
Re: Route flashing
Thanks for the speedy reply. I don't own a telephone to make that test.
Lost Internet before we had thunder and lightning this afternoon.
Fixes: 389
Re: Route flashing
Telephones (cheap ones can be obtained from the likes of Argos) are essential tools when you are on an ADSL/FTTC connection, but no matter.
Assuming you know your phone number, enter it into this link: Zen Broadband Status , and see if there is an OpenReach issue in your area.
If not, contact Plusnet and report your problem.
willcutforth
Fixes: 113
Re: Route flashing
I found a fault on the external line @RyanL987 it is a disconnection somewhere. It should be fixed within 72 hours.
Let me know if not.
 Will Cutforth
RyanL987
Re: Route flashing
Hi Will,
I don't believe the issue has been sorted as my camera hasn't come back online yet.
Luckily I'm away with work ATM but will need my internet back for Friday.
Is there any update please?
RealAleMadrid
Fixes: 68
Re: Route flashing
@RyanL987  It's only 25 hours since Will posted, I think you will have to wait a bit longer, it might be fixed by Friday if you are lucky.
willcutforth
Fixes: 113
Re: Route flashing
No update as of yet but like @RealAleMadrid said it will be closer to Friday that it will come back on. 13/07/23 23:59:59 is the exact ERT
 Will Cutforth
