Rock Bottom speed
- Rock Bottom speed
- « Previous
- Next »
Re: Rock Bottom speed
21-07-2010 12:08 AM
Fortunately my wife was in; he crawled over everything she tells me [but not everyone!] with a small radio picking up various noises. Coming back when he has a reach truck to finally give OK to the pole supplying our 'line in' & will replace that line up to BT internal socket. He has picked up mains noise but not certain if that is cause.
I'm leaving router on tonight [Tue]& for next day or so, having tried switching off last night. Last 7 hrs HEC/CRC/FEC all 4 up & FEC 577 down others 0. Assume if steady as she goes continues, over next 3 days we might get improved downloads
21-07-2010 2:09 PM
Thanks a lot. I'm happy that we did get a very quick response from the REIN guys on this one, maybe they are getting bored of me hassling them, well if that technique works so be it! I'm back on the phone to BTW now so I'll update you again when I have the full notes and can see the bigger picture more clearly.
Glad to hear it sounds hopeful so far (fingers crossed)
21-07-2010 3:07 PM
Namely they have replaced all the E and D side cabling (line between the exchange and street cabinet and also from the cabinet to the premises) they did also replace all the over and underground cabling. From the sounds of it monitoring equipment is also in place so its a bit of a waiting game now whilst more work is being done to try and pin-point the root cause of the fault.
I'm sorry I can't push for much more in the meantime but we will come back to this on the 26th which is BTW's next review date.
21-07-2010 5:07 PM
Being at the receiving end of the BT REIN gang could not have been much better; painstaking, methodical approach to identifying the 'Why?' of the existing problems. Yesterday 1.5hrs back this morning [another 4.5hrs] with hoist platform, replaced to house wiring from pole. Identified mains entry to house as a possible interference.
I was left with the sneaking feeling that somebody had kicked started BT, who were taking the task seriously & that can only be a push/shove from PN - well done.
John Anderson [BT], left a BT router as a stand by in case the Thomson might be faulty; Thomson after 5 hrs shows FEC Errors (Up/Down):7 / 895, CRC Errors (Up/Down):17 / 2, HEC Errors (Up/Down): 10 / 2. I do not know if this is good/bad.
At present BT speedtester d/loads show 3.8Meg & IP 5000 [was 1.8 and 2000 before BT came today] - will it last, I'll let you know! Champagne on hold at present but optimistic. Grateful thanks.
22-07-2010 9:37 AM
Always cautious after a number of false dawns in the past, I'm of no doubt that without PN's determination to get this sorted, I would still be struggling to even get a BT engineer to look @ things.
In the meantime, I'll keep a close watch & thank you Adam.
22-07-2010 10:57 AM
28-07-2010 3:19 PM
Just to keep you up to date (in a sense!) Our suppliers seem to have an issue which means that I cannot reach them by phone at the moment. Please bear with me as I will be in touch me more details as soon as I am able to gather them.
29-07-2010 11:08 PM
The REIN, BT engineer telephoned this morning to check on my experience/comments [this guy is really good, I've put his name on ticket should you care to give him star. Committed, knowledgeable & thorough]. He was surprised himself
Quote @ line quality after the tweaks, replacements etc. BT had implemented. I'm optimistic that this fix will supply the service that I had expected from PN when I signed up.
Whilst stability is now there, can I expect d/loads to creep up a bit more; I notice a gradual falling off but nothing dramatic, over last 2/3 days.
A big thank you for persevering on my behalf.
30-07-2010 10:41 AM
The REIN engineer involved has been a credit to us, good to see some great work from Openreach there.
Thanks for the kind words about me too glad to see that this at least for now (trying to be realistic rather than pessimistic there!) of course if the worst comes to worst then you know who to bother.
30-07-2010 7:33 PM
My line is now showing a steady, consistent connection & low snr. after 9/10 days - only hope it will continue. Seems it took PN's perseverance with BT, [ not to mention my frayed nerves & rants], to get a thorough assessment/action.
I'm more the wiser about the frailty and numerous likely problems that can plague some of us getting a reliable BB service through BT. I do not wish to go through this again.
So, thank you PN & well done; I am pleasantly satisfied with my lot & will now quieten down!
26-08-2010 8:22 PM
So glad your problem has been resolved. You kindly me offered words of encouragement when I was experiencing slow speeds and constant disconnections, some weeks ago.
I'm happy to report all ok at my end now although I only had 4 months to wait, well done for having the patience to wait 7 months.
I'm raising a glass to the hope that we both never have to go through this again, and of course to the persistent Adam.
Regards,
AngryPa
26-08-2010 9:16 PM
I have deliberately kept my head below the parapet, with arms, fingers & legs crossed that I would not wake up to the nightmare I was having in the first months of this year.
After much perseverence by PlusNet teckies as they pushed BT Openreach to get their act together, my moans & groans were listened to. Result, stable connections, no drops and best stats I've had since joining PN a year ago. It's been like this for over a month. I'm off for the next five weeks - just hope I will find the same stability when I return & switch the router on!
I'm a happy bunny so will join you in a toast. 'To Adam & the team'.
Cheers, Ian
- « Previous
- Next »
