Ridiculously slow?
- Re: Ridiculously slow?
Ridiculously slow?
01-10-2010 6:13 PM
I'm not crazy - that's terrible, right? I'm one unhappy customer at the moment.
01-10-2010 7:11 PM
Today 18:36 184 kbps (23kB/s) 368 kbps (46kB/s) Share
Today 16:10 241 kbps (30.1kB/s) 366 kbps (45.8kB/s) Share
Today 15:05 525 kbps (65.6kB/s) 364 kbps (45.5kB/s) Share
Today 14:25 747 kbps (93.4kB/s) 371 kbps (46.4kB/s) Share
Today 10:01 589 kbps (73.6kB/s) 364 kbps (45.5kB/s)
colinwaterson
01-10-2010 7:53 PM
Someone will be able to help if you can post your router stats
Sync Speed
Attenuation
SNR Margin
http://kitz.co.uk/adsl/frogstats.php
Also a Bt speed test
http://test.speedtester.bt.com:50301/
Also your current line speed ( PN profile)
https://portal.plus.net/my.html?action=data_transfer_speed ;
01-10-2010 8:22 PM
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 17.0 / 13.5
BT Speed test gives:
Download speed: 303kbps
DSL connection rate: 928kbps (downstream) 448kbps (upstream)
IP profile: 750 kbps
Current line speed: 350
If I read that correctly (and I'm only guessing really), I'd say that the line speed is terrible - but yet Sky somehow managed to deliver a faster connection on the same line. Apologies if I'm being thick.
04-10-2010 8:31 AM
04-10-2010 10:41 AM
I can see your profile had risen on BTs side to 1250 so I've set the profile on our side to match, hope that improves things for you.
05-10-2010 10:36 PM
05-10-2010 11:01 PM
i'm having a similar problem ...incredibly slow speeds and things such as iplayer hardly workig, if at all!!
we have three computers running off the same wireless network/router ...all the speeds vary on each computer and also vary throughout the day ...one of which takes up to 30mins just to load a page...which eventually fails as it times out
ive just done a bt speed test, result: 13mb
...and also just carried out the speed test on plusnet, results: download speed: 3411 kbps (426kB/s) upload speed: 199 kbps (24.9kB/s)
any suggestions?
thanks
05-10-2010 11:05 PM
Estimated line speed:
6 - Checked on 2010-09-22 11:51:04
Current line speed:
11000
i'm confused? surely this should a good speed? yet all out machines are running incredibly slow...
we have sync'd firewall settings etc.... i don't know what else to do?!?!
06-10-2010 12:09 AM
Current line speed:
11000
BT speed test: 13mb
Plusnet speed test:
Download: 115 kbps (14.4 kB/s)
Upload: 341kbps (42.6 kB/s)
Router DSL info:
Uptime:0 days, 2:05:09
DSL Type:G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:448 / 15,323
Data Transferred (Sent/Received) [kB/kB]:0.00 / 0.00
This is really shocking and increasingly annoying as the connection is getting slower and slower by the day. We have had problems for over a week now with no improvement.
06-10-2010 12:22 AM
06-10-2010 12:35 AM
06-10-2010 7:39 PM
I realize I must sound pretty stupid (I'm a girl, its allowed when it comes to computers) but how can I check whether one of us is running P2P?
06-10-2010 7:59 PM
06-10-2010 8:00 PM
How do you connect to your router, wired or wireless? If it's wireless have you tried wired?
