Reset high noise margin after fault resolution
- Re: Reset high noise margin after fault resolution
24-07-2009 8:14 PM
I recently had problems with a faulty modem/router and replaced it with a PlusNet provided Speedtouch 585v7. The connection has been rock solid for 3 days or so since replacing but it's connecting at a lower speed than the old one used to. Checking the stats it looks as though the fault has caused BT to set my noise margin to 15db. How can I go about getting this reset back to 6db? My line stats are:
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,184
Output Power (Up/Down) [dBm]: 11.5 / 11.5
Line Attenuation (Up/Down) [dB]: 6.0 / 10.0
SN Margin (Up/Down) [dB]: 22.0 / 15.0
David
David
Message 1 of 5
(1,081 Views)
4 REPLIES 4
27-07-2009 3:04 PM
Hi David,
It might be an idea to try rebooting the router first thing in the morning for the next few days to see if that results in BT instigating a recalculation of your SNR.
Message 2 of 5
(563 Views)
27-07-2009 7:49 PM
OK I'll give that a try. But how does the exchange tell the difference between me rebooting the router and the prior problem of the old router losing sync?
Message 3 of 5
(563 Views)
27-07-2009 7:59 PM
How often and how frequently.
However there is another factor - and no one knows what weighting it has - and that is the number of errors and the error rate
Message 4 of 5
(563 Views)
27-07-2009 8:34 PM
With a downstream attenuation of 10db and 15db SNR there shouldn't be ANY errors!!.
If there are, then as jim says , that could indicate some underlying problem and why the target SNR has not reduced.
It does take a while for the target to come down though, our office line has an attenuation of about 12 db and we had a line probelm about 9 months ago, target got set from 6 to 15db and after the line got fixed IIRC it took about 2 months of rock solid connection with minimal error counts to get back down to 6db.
Message 5 of 5
(563 Views)
