Replace my TP_Link VR2800 with another one
FIXED- Subscribe to RSS Feed
- Re: Replace my TP_Link VR2800 with another one
2 weeks ago
Hi all,
Recently, my TP_Link VR2800 stopped working, and I am currently awaiting delivery of a second hand replacement of the same model.
Unfortunately, I don't have a backup file for the original setup. Can anyone here please advise the easiest way to remake my FTTC connection?
Keith
Fixed! Go to the fix.
2 weeks ago - last edited 2 weeks ago
After a factory reset I would use the 'Quick setup' option to set it up. Make sure you have the DSL cable connected before you start.
Your broadband user name is youraccountname@plusdsl.net using the same password as the members centre
See https://www.tp-link.com/uk/support/download/archer-vr2800/ for more help
2 weeks ago
A footnote to my previous post, for FTTC/VDSL you need make sure VLAN 101 is configured when setting up the DSL connection
I am not sure if that is an option when using 'Quick setup' if NOT navigate from the home page
>Advanced Setting >Network >Internet
2 weeks ago
Thanks Dan the Van,
Up and running as soon as I remembered to put @plusdsl.net after my username 😁
