Regular ADSL Broadband or 4G/5G Router?
reene11
Hi everyone,
So now that the renovation of my flat is well underway, I got to the point where I was supposed to get my Internet sorted. Much to my chagrin, I discovered that the Virgin Media access that I thought was available based on the "Check broadband coverage" on the Rightmove property ad did not exist.
Had I known about this before, I would have probably looked elsewhere as we are two adults working from home for at least the remainder of the year, and an ADSL connection doesn't cut it.
While frantically looking for options I managed to come across the Three 5G broadband offer, and I am apparently in their coverage area. Do you have any experience with it? If 5G is not available, would a 4G router be better than the bog standard copper?
Thanks for the advice, as always.
2 REPLIES 2
Fixes: 118
Re: Regular ADSL Broadband or 4G/5G Router?
@reene11
Have you checked the following to see what's available to you via the OpenReach network.
Fixes: 251
It all depends!  Consult the availability checker.
There are areas where 3/4/5G is better than the wet string which passes for copper, just the same as there are places (even in cities) where mobile is painfully slow ... whilst in some rural locations, bog standard copper can be lightening fast!
There is no universal answer to your question.
