Recent peak-time speed problems (Nov 08) - Please read this!
- Recent peak-time speed problems (Nov 08) - Please ...
Re: Recent peak-time speed problems (Nov 08) - Please read this!
15-11-2008 10:23 AM
Quote from: HPsauce
Quote from: PB 3. Your IP Profile, as reported by Plusnet
Your current broadband speed is 8000 Kbps
That is not a "valid" real speed, suggesting PN hasn't received any data from BT
Quote from: PB 4. Information from the BT Speedtester
What was the IP profile reported by BT? (you didn't post it)
Sorry I should have pointed out the data for the speed tests was from PN. BT speedtester does not work for me (because i'm on LLU ?)
Router data: Sync consistently around 4192kbps / 640kbps
Cheers
PB
15-11-2008 10:26 AM
Quote from: PB the data for the speed tests was from PN. BT speedtester does not work for me (because i'm on LLU ?)
That explains it. Thanks.
15-11-2008 5:15 PM
15-11-2008 6:17 PM
Thanks. I figured it was probably Ticali causing most of my problems. The figures others were reporting (presumably on BT) didn't look quite so poor. at the moment I have a download speed of about 3.5 Mbps, so hopefully things haved stabilzed.
PB
15-11-2008 7:49 PM
still all over the place
latst
and BT after firefox updrade to 3.04 and reinstall flaky Java (just before the above
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 6014 kbps
todays graph below
16-11-2008 5:39 PM
Someone's downloading something. Why can't I?
Today 17:09 165 kbps (20.6kB/s) 77 kbps (9.63kB/s) Share
Today 14:44 1527 kbps (191kB/s) 341 kbps (42.6kB/s) Share
Today 11:53 1130 kbps (141kB/s) 293 kbps (36.6kB/s)
16-11-2008 7:03 PM
16-11-2008 9:55 PM
17-11-2008 8:21 AM
Clearly Gold traffic should not be dropping. Why is the Ellanoya not doing this automagically by dropping more and more silver/bronze traffic if required ... unless of course there is none of that traffic left to drop.
SW.
3Mb FTTC
17-11-2008 8:44 AM
scratchy.
17-11-2008 9:17 AM
@Pierre_pierre
Your graph is showing that the very slowest you've received is 2800 but your speeds are generally higher than that? I'd be interested to see what speeds a different speedtest gave at the same time as the lower results (which are still good IMO), as it could be congestion at the speedtester in your instance.
17-11-2008 9:19 AM
I've just had a quick look at our graphing from this end and things appear to have been generally okay over the course of the weekend. Sunday was a little busier than Saturday, but nothing dramatic with regards to gold drops.
I promise you that we're paying very close attention to this issue, and ultimately the main cause is down to extremely high numbers of customers being online (start of the Christmas shopping season, etc) and a gradual shift in usage trends (more streasming traffic, less P2P).
Mondays are generally our busiest night of the week, so Dave will be keeping a close eye on things, as ever.
17-11-2008 9:39 AM
17-11-2008 9:49 AM
I'm desticking this topic as the majority of speed complaints seem to be solved. If you do continue to have speed problems, feel free to post the requested information in this thread.
B.
17-11-2008 1:38 PM
Of course, I am not sure what's the cause of the lag and jagged throughputs (could be general Internet contention anyway) but I am examining my options in terms of products and providers. I understand that if I changed from BBYW Option 2 to BBYW Pro for gamers, ALL traffic will be flagged as high priority and therefore it should not be throttled at all. However, the Ellacoyas will still process the packets and such processing may incur some time penalty (especially at busy times when the switches are loaded).
Noticing that some of you are on the Pro Option I would be interested to know what is your experience with respect to initial lag and how often have you found your download speeds affected by throttling?
