Random disconnects, is my router breaking down?
- Re: Random disconnects, is my router breaking down...
11-12-2007 10:38 PM
Message 1 of 9
(2,001 Views)
8 REPLIES 8
Re: Random disconnects, is my router breaking down?
11-12-2007 11:15 PM
Dec.12.2007 00:15:14 i802_1x:Supplicant 00:1c:c3:3a: timed out after 300 idle seconds
Message 2 of 9
(697 Views)
11-12-2007 11:45 PM
Well It just disconnected again whilst browsing a website. Looked on the router page and seen this
ADSL Status DISCONNECTED
Message 3 of 9
(697 Views)
12-12-2007 12:29 AM
Reading that log I'd say it is very, very likely that there is an idle timeout setting in your router. I think you need to check the manual/helpfiles for that - alternatively there may be someone who knows the router who may be able to point you in the right direction. Posting the exact model number may help us pin it down.
Message 4 of 9
(697 Views)
12-12-2007 7:12 AM
My router is a belkin
model number is - F5D7632-4
Message 5 of 9
(697 Views)
12-12-2007 9:35 AM
Well a quick Google led me to find the user manual in which I found on page 33:
Quote 5. Disconnect after X...
The Disconnect feature is used to automatically disconnect the router from your ISP when there is no activity for a specified period of time. For instance, placing a checkmark next to this option and entering 5 into the minute field will cause the router to disconnect from the Internet after 5 minutes of no Internet activity. This option should be used if you pay for your Internet service by the minute.
Message 6 of 9
(697 Views)
12-12-2007 12:50 PM
Thanks for that. I can see that on page 34 it shows the disconnect option in the screenshot.
I am currently at work but will check this evening.
Message 7 of 9
(697 Views)
12-12-2007 5:03 PM
hi again, i found the following setting on my router
Idle Time (Minute) >
this was set to 5 so i changed it to 0. will wait and see what happens now. thanks everyone.
Message 8 of 9
(697 Views)
12-12-2007 5:31 PM
Hi Jonny,
I would be very surprised if that does not fix your problem.
Let us know anyway
Let us know anyway
Message 9 of 9
(697 Views)
