Random WAN disconnects started 18th October and nearly daily since
400ixl
As of the 18th October I have been getting frequent WAN drops, anything from every other day to multiple times a day. Any idea of possible causes? Tried the text fault reporting, but of course by the time that runs the connection is back up.
The history of the drops from the router logs are:
12:58:31 01 Nov. DSL Link Down: duration was 4009 seconds
11:51:17 01 Nov. DSL Link Down: duration was 68472 seconds
16:49:39 31 Oct. DSL Link Down: duration was 276189 seconds
13:06:05 28 Oct. DSL Link Down: duration was 4167 seconds
11:56:13 28 Oct. DSL Link Down: duration was 66092 seconds
17:34:15 27 Oct. DSL Link Down: duration was 9705 seconds
14:52:05 27 Oct. DSL Link Down: duration was 15310 seconds
10:36:30 27 Oct. DSL Link Down: duration was 113160 seconds
03:10:05 26 Oct. DSL Link Down: duration was 66006 seconds
08:49:34 25 Oct. DSL Link Down: duration was 42811 seconds
20:55:38 24 Oct. DSL Link Down: duration was 35060 seconds
11:10:53 24 Oct. DSL Link Down: duration was 158890 seconds
15:02:18 22 Oct. DSL Link Down: duration was 4639 seconds
13:44:34 22 Oct. DSL Link Down: duration was 4466 seconds
12:29:43 22 Oct. DSL Link Down: duration was 79916 seconds
14:17:19 21 Oct. DSL Link Down: duration was 145 seconds
14:14:29 21 Oct. DSL Link Down: duration was 21 seconds
14:13:43 21 Oct. DSL Link Down: duration was 67853 seconds
19:22:25 20 Oct. DSL Link Down: duration was 58611 seconds
03:05:09 20 Oct. DSL Link Down: duration was 182016 seconds
00:25:38 18 Oct. DSL Link Down: duration was 2499774 seconds
02:02:19 19 Sep. DSL Link Down: duration was 1298563 seconds
01:19:10 04 Sep. DSL Link Down: duration was 5342822 seconds
04:10:06 05 May. DSL Link Down: duration was 526014 seconds
As you can see it has become more frequent since the 18th October. There have been no changes in the infrastructure or configuration during this period.
A more detailed WAN log for today is:
12:59:35 01 Nov. WAN Sensing Auto sensing Complete
12:59:34 01 Nov. WAN Sensing Auto sensing Running
12:59:34 01 Nov. Success - secondary DNS servers
12:59:34 01 Nov. Success - primary DNS servers
12:59:34 01 Nov. WAN connection WAN2_INTERNET_PTM connected
12:59:05 01 Nov. DSL Link Up: Down Rate=77314kbps
12:58:57 01 Nov. WAN Auto-sensing detected port DSL WAN
12:58:33 01 Nov. WAN Sensing Auto sensing Complete
12:58:33 01 Nov. WAN Sensing Auto sensing Running
12:58:33 01 Nov. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
11:52:10 01 Nov. WAN Sensing Auto sensing Complete
11:52:10 01 Nov. WAN Sensing Auto sensing Running
11:52:10 01 Nov. Success - secondary DNS servers
11:52:10 01 Nov. Success - primary DNS servers
11:52:10 01 Nov. WAN connection WAN2_INTERNET_PTM connected
11:51:50 01 Nov. DSL Link Up: Down Rate=77073kbps
11:51:42 01 Nov. WAN Auto-sensing detected port DSL WAN
11:51:19 01 Nov. WAN Sensing Auto sensing Complete
11:51:18 01 Nov. WAN Sensing Auto sensing Running
11:51:18 01 Nov. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
2 REPLIES 2
Legend
Fixes: 290
Re: Random WAN disconnects started 18th October and nearly daily since
@400ixl
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
400ixl
Thanks jab1
Line test seemed clear.
I had tried the SMS test when it happened the other day but that came back as no problem. Tried it again today and it has come back with a fault and an engineer is being deployed tomorrow to look at it.
Thanks for your response, lets see where the engineer gets to tomorrow.
