Radius Log Request
- Radius Log Request
Re: Radius Log Request
04-09-2015 8:57 AM
Sync speed is also constant. - I check RS every so often, when the display drops to 0 - or below.
Will continue to monitor.
04-09-2015 9:22 AM
04-09-2015 9:27 AM
04-09-2015 9:31 AM
04-09-2015 9:37 AM
04-09-2015 12:21 PM
07-09-2015 11:49 PM
08-09-2015 7:23 AM
15-09-2015 9:39 AM
I'm aware Anotherone, who's been patiently helping me, is away at the moment, but is there anyone else more technically aware than me who can comment?
The problem has not gone away, and I am still running RSL, but more important things are currently occupying much of my time.
Thanks to anyone who cares to look.
16-09-2015 6:16 PM
BT speed test result:-
1. Best Effort Test: -provides background information.
Download Speed
6.82 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.82 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.78 Mbps
Upload Speed
0.59 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.59Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Current line speed: 10.4Mbps
Will post RSL graphs in another reply - that is running on the laptop - this is being posted from the desktop.
16-09-2015 6:25 PM
Uptime: 0 days, 1:57:01
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 780 / 7,688
Data Transferred (Sent/Received) [MB/MB]: 64.85 / 655.41
Output Power (Up/Down) [dBm]: 12.2 / 20.3
Line Attenuation (Up/Down) [dB]: 16.6 / 33.5
SN Margin (Up/Down) [dB]: 5.7 / 13.6
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 589 / 0
FEC Errors (Up/Down): 6,484 / 251
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down):
16-09-2015 6:50 PM
16-09-2015 7:34 PM
16-09-2015 8:07 PM
21-09-2015 4:31 PM
