Radius Log Request
- Radius Log Request
Re: Radius Log Request
29-07-2015 8:46 AM
29-07-2015 10:37 AM
29-07-2015 11:56 AM
Think I'm nearly there - it least bed is not quite so inviting.
30-07-2015 7:55 AM
30-07-2015 2:37 PM
24-08-2015 8:39 AM
SNRM graphs for 21/8/15 - these are from the laptop as my desktop keyboard is u/s, and the spare is at my sisters.
Two incoming phone calls - one at 1106 which appears to have played havoc with the connection, one at 1542 which only affected the u/s.
Until I reclaim the keyboard, there will be no overnight graphs.
24-08-2015 8:45 AM
Two calls - one at 1028 that had no effect, one at 1418 that did.
24-08-2015 8:51 AM
24-08-2015 7:32 PM
What's the Quiet Line Test giving at present? If you are getting plenty of crackling type noises you might as well try the Phone Troubleshooter (as found here) unless you still have a fault ticket open, and hope the automated test picks up the fault and reports it.
24-08-2015 9:55 PM
I haven't run a QLT since my return - will do that sometime tomorrow. Crackling/distortion on calls is intermittent, sometimes at the start of call and then clears, sometimes well into the call (if it is a long one).
I have no fault ticket open at this time, so will run the Phone Troubleshooter. Before I do that, can you please advise (in your opinion), if you think the fault is definitely external? Sorry to be a pain on this, but I don't want PN/BT coming back and blaming my equipment, if there is any chance that it could be.
24-08-2015 10:49 PM
25-08-2015 7:56 PM
One outgoing and one incoming call, neither of which caused any noise, but as usual, caused the SNRM to fluctuate during the call.
Don't want to disturb anything at the moment - not had a PPP drop or a re-sync since 1640 on the 22nd - so will leave things alone until/unless I get another bout of instability.
Thanks for your help/suggestions so far.
25-08-2015 8:29 PM
03-09-2015 8:25 AM
Just for info, here are yesterdays SNRM graphs - interestingly, I had NO phone calls at all, so all variations are due to some external influence.
04-09-2015 12:45 AM
As for the other two DS SNRM excursions to 0, odd not quite sure what to deduce from them. That is unusual behaviour, with no similar drop on the US.
