REIN trouble (mostly fixed)
- REIN trouble (mostly fixed)
Re: REIN trouble (DLM strangely inactive)
05-07-2013 7:27 PM
http://rsux.plainroad.me.uk
I've only tried the windows version but it's a good alternative to routerstats.
05-07-2013 7:29 PM
05-07-2013 7:36 PM
05-07-2013 7:41 PM
As far as Plusnet's tests, hmm, MTBE DS 192, ILQ Amber. Not nice.
06-07-2013 6:13 AM
06-07-2013 9:00 AM
06-07-2013 12:30 PM
Quote from: ejs I've started dumping and saving all the stats at 10 second intervals, next job is to re-arrange the output into a more usable format.
A spot of home electronics will also serve to keep you out of the sunshine longer if you get bored of reinventing the wheel, or can't borrow a Windows laptop.
06-07-2013 1:05 PM
Quote IN=ppp0 OUT= MAC= SRC=178.216.224.209 DST=my.ip.ad.dr LEN=48 TOS=0x00 PREC=0x80 TTL=110 ID=10166 DF PROTO=TCP SPT=3261 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
Or the number of packets the router's traffic shaper manages to drop:
[tt]cat /proc/net/priowrr
Enqueue Dequeue Maxqlen Drops Flushed
20 20 1 0 0
0 0 0 0 0
0 0 0 0 0
653300 653300 26 4769 0
[/tt]
06-07-2013 1:26 PM
06-07-2013 1:47 PM
PS. I liked the links
06-07-2013 5:02 PM
[tt]AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 708 DS Connection Rate: 3558
DS Line Attenuation: 60.4 DS Margin: 6.0 (+2)
US Line Attenuation: 36.9 US Margin: 5.3
US Payload : 121674336 DS Payload: 1474279680
US Superframe Cnt : 5645894 DS Superframe Cnt: 5645894
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 543 Severely Err Secs: 12
Frame mode: 0 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 1669
Trained Mode: 16 Selected Mode: 1
ATUC Vendor Code: 54535443 ATUC Revision: 3
Hybrid Selected: 3 Trellis: 1
Showtime Count: 4 DS Max Attainable Bit Rate: 3832 kbps
BitSwap: 1 US Max Attainable Bit Rate: 1104850 bps
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -366
Total init. errors: 0 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 0 Last showtime init. timeouts: 0
ATUC ghsVid: b5 00 54 53 54 43 05 10
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 32 FEC: 211010 NCD: 0
LCD: 0 HEC: 23
[Downstream (RX) Interleave path]
CRC: 1212 FEC: 33191733 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 2534882
Idle Cell Cnt: 157733939
Tx Packets Dropped Count: 0
Tx Bad Packets Count: 425
[Downstream/RX)]
Good Cell Cnt: 30714160
Idle Cell Cnt: 774699129
Bad Hec Cell Cnt: 13094
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 1706567
Rx PDU's: 2497453
Tx Total Bytes: 204056021
Rx Total Bytes: 2954715213
Tx Total Error Counts: 0
Rx Total Error Counts: 38156
[/tt]
06-07-2013 6:41 PM
Edit: Added scalable PDF graphs - there was also some huge burst of noise at 10:46 which very nearly took out the DSL, I don't think it was a reporting glitch because all the stats were affected - ds nm was 2.1, ds and us sync speeds were zero, but somehow didn't drop adsl entirely.
07-07-2013 7:36 AM
08-07-2013 6:44 AM
08-07-2013 10:40 PM
If it weren't for the fact it was a Saturday, I've hazarded a guess that just before 1800 was someone switching on a (plasma?) TV/Sky Box to watch the news, but the SNRM behaviour from 2200 to ~2300 doesn't match that theory too well and again from ~0245 to ~0430
When it started Sunday at 2048, the SNRM drop was much greater than Saturday, and then we have this different but still rather strange behaviour from ~2256 to ~0445 ish.
Well your guess as to possibilities will probably better than mine from local knowledge.
Here's one stab in the dark - SNRM drop + errors, TV and Sky box on, fluctuating SNRM - Sky box recording, TV off.
Another stab, a neighbour's Modem/Router which has started to reach failure point turned on, crosstalk causes SNRM drop (yes that is a definite possibility if theirs and/or even your lines are not too well balanced), later when computer off and Modem/Router is idling, it suddenly goes unstable for a while.
I mean one could come up with all sorts of theories, until you narrow down the location, it's all hypothesis. Except the frequencies (tone numbers) of the dips in the Bits/Tone and SNRM/tone suggest in favour of the twp stabs I've made because they are the sorts of frequencies from odd harmonics of Switch mode PSUs. Having said that, it could be anything with a SMPS, but it's fitting the usage pattern that's the slight odd one
