Question about my line stats.
- Re: Question about my line stats.
20-10-2011 8:28 AM
One question done,now to why one router has 15db less upstream attenuation,both are netgears,the lower one is a DG834 and the higher is a DG834GT.
20-10-2011 8:35 AM
20-10-2011 10:08 AM
20-10-2011 10:54 AM
20-10-2011 8:03 PM
ADSL Link Downstream Upstream
Connection Speed 7616kbps 448 kbps
Line Attenuation 25.0 db 15.5.5 db
Noise Margin 9.3 db 21.0 db
The upstream nm might be different,didnt jot the stats down on paper,but thats a seriously better connection than i have!
Would that indicate theres more to my lack of speed than a different cab?
21-10-2011 11:29 AM
Your attenuation being twice your neighbour's suggests either you live 1.8km from your neighbour ( ), your line to the exchange is 1.8km longer due to connection via a different cabinet taking a much longer route ( ) or there is a serious problem with your connection. Definitely time for some serious diagnostic work starting by eliminating problems with your internal wiring.
21-10-2011 12:02 PM
21-10-2011 5:51 PM
21-10-2011 6:37 PM
You can link the resulting fault report to this thread.
21-10-2011 7:32 PM
22-10-2011 10:23 AM
Guess BT don`t like me.
24-10-2011 9:34 AM
Connection seems stable,just compounds the fact that my sync seems to be out of odds with others around me.
......The 3 drops in my NM was me unplugging the ethernet cable on the pc,not through a drop in sync.
24-10-2011 12:56 PM
Connection Speed 5024 kbps 448 kbps
Line Attenuation 49.0 db 31.0 db
Noise Margin 5.5 db 21.0 db
Equipment pretty much the same apart from the faceplate and shielded cable to the router,looks like i`ve had some deterioration in my line quality since `Feb `09.
24-10-2011 5:07 PM
Your current sync rate of 4832 will give you a profile of 4000, as would have your sync rate of 5024 that you quoted in your last post. As it's 3500 at the moment it can take a while (about 72 hours) with a constant connection for it to rise.
Jojo
24-10-2011 5:26 PM
Like was said,someone just 15 seconds from my front door has a downstream attenuation (25db) that puts him exactly at 1.8km from the exchange (just like i am) but my attenuation (50db) has me at 3.6kms.
Now i dont live 1.8kms away from him and to have my line (if this is the case) take a route that is double the distance is just a bit puzzling.
