Puzzling technicolour wireless disconnection
- Re: Puzzling technicolour wireless disconnection
22-12-2013 1:20 PM
This puzzles me: surely the wireless connection should be independent of the wired one?
23-12-2013 12:01 PM
23-12-2013 2:12 PM
Does the same happen if, leaving the Ethernet cable connected, the wired computer is 'hibernated' (rather than shut down)?
23-12-2013 4:37 PM
Formidable, sir! Yep, when the wired PC is hibernated, the wireless facility for the other PC is terminated!
Not good cos it means that I'm unable to do any routine maintenance work on the wired PC unless I'm prepared to lose wireless on the other PC.
Any solutions?
23-12-2013 7:42 PM
On my TG582n (ADSL) with 8.4.4.J software, wireless continues to work (to an android tablet and TV) when I hibernate my wired Windows Vista desktop PC. The Ethernet light on the router turns off when my PC hibernates (nothing else uses a wired connection). If the PC is shut down the Ethernet light stays green.
If you go into Network and Sharing Center, click Status against Connection then 'Disable' does wireless continue to work? (Those steps are for Vista, the process might be different for other versions of Windows.)
23-12-2013 8:35 PM
When i followed your suggestion (in XP it's Control Panel > Network Connections > LAN or High Speed Internet > Local Area Connection and disabled it, the WiFi light on the router went out.. so no, it doesnt work in that scenario.
24-12-2013 3:49 PM
When the green light on the wireless button goes out will it turn on again if you press the button (and hold for a few seconds - normally until the light turns on)?
Another thought - is 'eco mode' turned on? I think that turns wireless off if believed to be inactive.
24-12-2013 4:16 PM
No, pressing the button doesn't result in the wireless light coming on again. The only way I could get wireless to reconnect was by reconnecting the ethernet cable!
24-12-2013 4:40 PM
24-12-2013 5:09 PM
Have a great xmas sprayxt
24-12-2013 8:05 PM
Another thought which I don't think has been answered already …
If the router is restarted with nothing connected to it (Ethernet cables unplugged at start up) does the wireless turn on and continue working normally?
24-12-2013 9:21 PM
Where is ecomode on the tg582n? I do wonder if this is part of my issue posted elsewhere here. I am running rev10 of the plusnet firmware. Its adsl only btw
24-12-2013 11:23 PM
Home > Home Network > Interfaces > WLAN: <your SSID>
On my router that is set to "No" (checkbox not ticked).
The router Help page says
[quote=TG582n help page]
Power Reduction Enabled:
To enable power reduction on the wireless access point select the check box. When power reduction is enabled, the wireless access point will be disabled automatically if no associated stations are present.
26-12-2013 10:46 AM
I do wonder if there are random issues with my wireless. I have noticed, but not taken much notice of an issue where both my android devices suddenly flash up 'connected to plusnetwireless******' when they seem to be already connected. i wonder if there are random disconnections of the wireless maybe even for very very short periods of time.
I am going to disable eco-mode, and also reading NPRs telnet guide there is an option to Change wireless n speed (TG582n only) and also Wireless n tweaks (TG582n only)
Would any of these be useful?
27-12-2013 1:17 AM
Since eco mode is not enabled on my router its wireless should not be turning off even though battery powered wireless devices are inactive. So no delay if a wireless device tries to communicate. Even so my XP laptop regularly pops up "connected" messages, but only very occasionally (less than once per week) does my Nexus 7 tablet do this.
I'll leave you to decide whether either of those scenarios is relevant to the behaviour you've seen.
It doesn't seem likely that tweaking wireless n settings would affect connectivity, but the best way to find out is to try it.
David
