Puzzled about line speed readings in router
- Re: Puzzled about line speed readings in router
31-01-2012 11:03 PM
An on-line speed check site shows that I get around 6Mbps download and 400Kbps upload speeds. But when I look at my Thompson router DSL Link Information screen (see attached screenshot) it shows a download speed of about 15Mbps and an upload speed of around 450Kbps.
The PlusNet Help & Support pages say that my current connection should provide me with 'Up To' 20Mbps. So the questions seems to be, if my reported line speed is managing 15Mbps, why am experiencing only 6Mbps?
31-01-2012 11:41 PM
what does it say for "Current line speed" ?
01-02-2012 7:20 AM
01-02-2012 7:50 AM
You should only expect 88.2% of the speed that your router syncs at, so that 15,192Kbps should work out 13.3Mbps (which the current line speed in the above post should match, but there's a known issue with delays in these figures updating)
Have you tried running the speed tests in different browsers/using different sites (speedtest.net is usually pretty accurate for me)
What results do you get from a BT speed test?
http://www.speedtester.bt.com/
01-02-2012 9:49 AM
BT have recently finished installing fibre to all the distribution boxes in the town. The box which serves my street is about 300m away. Don't know if this could be anything to do with the odd speed readings.
01-02-2012 10:05 AM
I'm wondering if this is related to the issues reported here: http://community.plus.net/forum/index.php/topic,102123.msg866715.html#msg866715 let me know if you think otherwise
01-02-2012 10:16 AM
01-02-2012 11:07 AM
01-02-2012 11:59 AM
01-02-2012 12:07 PM
I'll post a fault report and see what that turns up.
Thanks for all the help
01-02-2012 12:41 PM
Quote which give me up to 100Mbps
'Up to' are the crucial words there. Homeplug speed is very dependent on the wiring and whether plugs are on the same circuit.
Is it possible to test with a direct wired ethernet connection to the router ? just to eliminate the Homeplugs as a restriction.
01-02-2012 1:31 PM
01-02-2012 1:36 PM
01-02-2012 1:48 PM
I'll just have to nail proper Ethernet cable around all the door frames and skirting boards. But for some reason my wife says she'd kill me if I did.
01-02-2012 2:12 PM
Are all the LEDs on the front of both homeplugs green ? or are some orange or red ?
