Profile Stuck?
- Re: Profile Stuck?
- « Previous
- 1
- 2
- Next »
Re: Profile Stuck?
12-11-2012 5:49 PM
Hi (Again!)
Apologies but I seem to have a stuck IPprofile again following some router resets yesterday whilst I was trying to work out why auto came back as G.DMT instead of ADSL2+...I've now set it to use ADSL2+ rather than leave it on "auto".
Running the BT Speed Test shows my profile as 12.25Mbps but Plusnet has stayed at 7.1 and speed tests resulting in 6.5 Mbps (the sync would come from the time it connected as "G.DMT" when the modulation was "auto" and gave a 7616Mbps sync).
My router stats are now:
ADSL Information (ADSL Firmware Version: E.67.36.1 )
ATM Statistics TX Blocks RX Blocks Corrected Blocks Uncorrected Blocks
626649 7018313 0 281147
ADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
ADSL2+ SHOWTIME 1083900 13882300 2.5 24.5
The one aspect that does concern me is the sheer number of Uncorrected Blocks, which was significantly lower on G.DMT. Note: This is after 29 hrs router uptime. Also, given the number of uncorrected errors , can I ask if this means interleaving is not in use on this connection?
Message 16 of 19
(191 Views)
Re: Profile Stuck?
13-11-2012 10:25 AM
Hi grahamn,
Sorry about that - just updated your profile on our side to 12200 to match that on BTs side of things, hope you get an improvement
Message 17 of 19
(191 Views)
Re: Profile Stuck?
13-11-2012 4:01 PM
Hi Matt - Many thanks much better. can I just check that I do have interleaving on the line as well?
regards,
Graham
regards,
Graham
Message 18 of 19
(191 Views)
Re: Profile Stuck?
13-11-2012 4:49 PM
Message 19 of 19
(191 Views)
- « Previous
- 1
- 2
- Next »
