Problems on LLU last night????
- Re: Problems on LLU last night????
01-11-2007 6:55 AM
Quote Wed, 2007-10-31 22:06:45 - Initialize LCP.
Wed, 2007-10-31 22:06:45 - LCP is allowed to come up.
Wed, 2007-10-31 22:07:45 - Initialize LCP.
Wed, 2007-10-31 22:07:45 - LCP is allowed to come up.
Wed, 2007-10-31 22:08:45 - Initialize LCP.
.........and so forth until
Thu, 2007-11-01 00:49:57 - Initialize LCP.
Thu, 2007-11-01 00:49:57 - LCP is allowed to come up.
Thu, 2007-11-01 00:49:57 - CHAP authentication success
01-11-2007 7:32 AM
During the outage, the DSL link was up, but my (Speedtouch 585) router reported failure of ATM loopback test and no PPP connection.
I rang the help line, but got fed up of listening to the music after ten minutes.
01-11-2007 8:57 AM
Was there work done on THN-AG2? if so that's why. Maybe there was a problem at Tiscali's end?
01-11-2007 9:06 AM
01-11-2007 9:09 AM
Quote Our supplier is investigating a power fault on their backhaul to these exchanges which may be causing issues.
Areas Affected: Cheshire, Warrington, Chester, Winsford, Heswall, Blackburn, Padham, Skelmersdale, Blackburn and Carlisle LLU exchanges
01-11-2007 9:10 AM
02-11-2007 7:10 AM
Presuming that early this morning...
Quote Fri, 2007-11-02 01:58:10 - LCP down.
......etc
Fri, 2007-11-02 02:37:20 - LCP is allowed to come up.
Fri, 2007-11-02 02:37:49 - CHAP authentication success
was part of the same problem, although it was only 39 mins this time
02-11-2007 7:55 AM
- Skelmesdale
- Basingstoke
- Maidenhead
- Newbury
- Tilehurst
- Thatcham
- Wokingham
They also performed some work across their central bandwidth links although I'm not 100% sure whether or not this will have impacted our customers.
02-11-2007 8:54 AM
02-11-2007 1:55 PM
02-11-2007 1:58 PM
I don't think your problem is the same as the LLU issues as you don't appear to be connected via this.
You can check if you are on LLU by visiting the gateway checker at http://usertools.plus.net/@gateway, if you are on LLU it will show up as THN-AG2
02-11-2007 2:03 PM
02-11-2007 2:05 PM
05-11-2007 12:21 PM
I've just had a quick look at your line and I'm seeing you as being connected solidly for the last 2 days, so hopefully, everything appears to be well now
