Premier Option 1
- Premier Option 1
- « Previous
- 1
- 2
- Next »
Re: Premier Option 1
27-10-2007 9:59 AM
you can change this here https://portal.plus.net/products/upgrade/change_data_transfer.html
It's not a permenant change as you can change your package once a month and if you don't touch the fixed cost/PAYG option then this will happen and you'll then get 128K speeds when you use up your allowance
If you want to PAYG as you go simply tick the box at the bottom left and this will charge you £1 per GB over your allowance and will keep your speeds to normal
I hope this helps and don't worry, questions are good
Pete
Pete
Message 16 of 20
(361 Views)
27-10-2007 11:09 AM
Pete
Thanks for that.
David
Thanks for that.
David
Message 17 of 20
(361 Views)
27-10-2007 9:12 PM
Your welcome
Pete
Pete
Message 18 of 20
(361 Views)
22-11-2007 2:06 PM
Out of curiosity, for those of us who still have the Broadband Premier packages, is it possible to upgrade, but not to BBYW. That is, switch to from Broadband Premier - Option 1 to Option 2 for instance?
Message 19 of 20
(361 Views)
22-11-2007 2:13 PM
If you goto this page:
https://portal.plus.net/upgrade_process.html?memberheader=upgrade
You will be able to see which products that you can upgrade to. I'm fairly certain that you can't upgrade to another Premier product as they are no longer for sale.
Message 20 of 20
(361 Views)
- « Previous
- 1
- 2
- Next »
