Possible Speed Fault
- Re: Possible Speed Fault
22-10-2011 9:14 PM
I seem to having an issue with my internet down speed over the last couple of weeks. I recently have only seemed to be getting 2-3mps where I have previously getting around 6mps.
I have recently swapped to another product but don't think my line speed should be affected this much.
Router Stats
System Up Time 20:16:25
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN 100M/Full 382880 517936 0 551 9889 20:16:12
LAN1 100M/Full 37462 39156 0 15106 2592 00:40:00
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 54M 336196 228928 0 6837 198 20:16:18
Plusnet Details
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-07-29 13:22:03
Current line speed:
21 Mb
BT Speed Test
Download Speed
3925 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 3925 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8064 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7114 Kbps
Any help on this would be much appreciated
23-10-2011 1:09 AM
Does your router give sync speed, attenuation and noise margin information as well as that you posted (you might need to click a button to see that)?
23-10-2011 10:04 AM
The router has a wired connection to my PC the only Wireless connections are from a PS3 or Iphone.
I had a look through my router yesterday and again this morning looking for sync speed etc but I don't think my router gives this information ( Its a Netgear WGR614) if that helps. Is there any other way I can obtain this information ?
23-10-2011 10:16 AM
23-10-2011 10:43 AM
I have my router linked through a separate modem which is obviously where the stats would be !
I have posted the stats below
Line Rate 8064 kbps 448 kbps
Attainable Line Rate 10304 kbps 1332 kbps
Noise Margin 15.7 dB 31.0 dB
Line Attenuation 11.9 dB 6.5 dB
Output Power 17.9 dB 10.0 dB
23-10-2011 1:31 PM
It looks like your modem is connected using ADSL1 (up to 8Mbps). Does it support ADSL2+ (up to 20Mbps)?
23-10-2011 5:15 PM
My modem does support ADSL2+, but if I try and set it to this the modem does not connect so I cannot leave it on that setting,
23-10-2011 10:19 PM
It looks like you are provisioned on ADSL1 even though you are on 21CN. I suggest raising a ticket to request being switched to ADSL2+.
Does your modem have a multimode setting? That will normally connect with ADSL2+ if it's available or ADSL1 if not.
23-10-2011 11:04 PM
I have my DSL mode set to auto on my modem at the moment so it does look like it is defaulting to ADSL as a result of that. Any settings apart from that are causing the modem to drop connection,
24-10-2011 12:43 AM
24-10-2011 4:02 PM
It seems that when you were put onto 21CN it was on the 'up to 8Mbps' service (ADSL1). I have now placed an order to put it in ADSL2+ This should complete tomorrow, so let me know how it goes.
Jojo
p.s. I've raised a ticket to confirm this
25-10-2011 1:25 PM
Thanks for that, I think my line must have been changed as my line speeds have increased quite a bit !
So far everything is looking good. Thanks for your help and for everyone else who has contributed to this thread
Cressa
25-10-2011 2:23 PM
