Possible Hot Vlan
Faizan786
Possible Hot Vlan
35 REPLIES 35
Fixes: 378
Re: Possible Hot Vlan
What are your 'normal' figures - those are atrocious?
Faizan786
39 to 44mb max DL
6.1mb UL
Fixes: 378
Ah, so you are on FTTC not FTTP. Which router are you using?
Faizan786
Bt hub
Faizan786
Its back to full, its been like this in the early evenings.
Fixes: 378
Wich version, and can you post a screen shot of you router stats please.
Faizan786
Is that Home - Advanced settings - Technical Log
Information or Event log?
Fixes: 378
Both, if possible. I don't know the BT Hubs, but does yours allow the full event log to be exported in .csv format?
Faizan786
lost me there mate. Im a screenshot kinda guy and both info/event don't fit in one picture. Is there a specific info i can tell you that your after.
Fixes: 378
If you are using a desktop/laptop, the info should - see the screenshot below (taken from a PN Hub2) which gives us most of the data required.
Fixes: 475
Moderator's note:
Thread moved from Full Fibre to Broadband
Faizan786
Opera Snapshot_2024-10-30_214538_192.168.1.254.pngOpera Snapshot_2024-10-30_214538_192.168.1.254.png
Do data rates of around 46Mbps with such high attenuation figures look right?
Fixes: 378
@Anonymous I was wondering about that too, but got distracted. I also note that DSL  uptime is low. Wondering if the OP has a fault?
