Poor speeds since outage oin 1st June
- Poor speeds since outage oin 1st June
03-06-2013 6:57 AM
up until Saturday I've had a rock solid connection giving me between 49 & 53 Mbps. Since Saturday's outage this is now more like 33-37. Suggestions as to why? and correct sequence to see if I can get any more?
Latest BTW test shows:-
Up 13
down 35
IpProfile 56.72
Up 13
down 35
IpProfile 56.72
Message 1 of 7
(1,127 Views)
6 REPLIES 6
Re: Poor speeds since outage oin 1st June
03-06-2013 12:47 PM
I've checked over your connection and can't see that your sync speed has changed. Are you currently connecting with a wired or wireless connection?
Message 2 of 7
(572 Views)
03-06-2013 1:10 PM
Wireless, as always, but nothing has changed at this end - all the kit is still in the same places that it usually is.
Might a bit of gateway hopping help, or should I power off the BT modem as well?
Message 3 of 7
(572 Views)
03-06-2013 5:12 PM
My download is OK but my upload has dropped to 5Mbps from about 6 ish
Message 4 of 7
(572 Views)
03-06-2013 5:32 PM
Would you be able to try a PPPoE connection? Your sync rate is still in the 50Mb/s area.
Message 5 of 7
(572 Views)
03-06-2013 7:10 PM
Quote from: gwillym Might a bit of gateway hopping help, or should I power off the BT modem as well?
A gateway hop wouldn't hurt, should be no need to power off the BT modem, just run another BTW diagnostic after the gateway hop to ensure your BT IP Profile is still the same (if so then your sync is still OK).
Call me 'w23'
Message 6 of 7
(572 Views)
04-06-2013 9:05 AM
All back to normal this morning - weird!
Message 7 of 7
(572 Views)
