Plusnet blocking Open VPN port 1194 TCP and UDP
bobpullen
Fixes: 327
Re: Plusnet blocking Open VPN port 1194 TCP and UDP
Right, I've reverted the change.
Although to be fair, it looks to me like UDP traffic is still getting to you Huh This is from a Vodafone connection:
$ traceroute -e -P UDP -p 1194 150.143.[REDACTED]
traceroute to 150.143.[REDACTED] (150.143.[REDACTED]), 64 hops max, 52 byte packets
  1  192.168.43.46 (192.168.43.46)  3.361 ms  2.617 ms  1.734 ms
  2  * * *
  3  192.168.213.21 (192.168.213.21)  97.887 ms  156.679 ms  72.388 ms
  4  192.168.213.22 (192.168.213.22)  69.346 ms  108.767 ms 116.252 ms
  5  * * *
  6  * * *
  7  63.130.104.194 (63.130.104.194)  176.494 ms  105.906 ms 103.193 ms
  8  ae13-100-xcr1.ltw.cw.net (195.2.23.77)  88.128 ms  87.059 ms 111.099 ms
  9  ae32-xcr1.lns.cw.net (195.2.24.126)  140.652 ms  102.770 ms 144.044 ms
10  t2c3-ae1-0.uk-lon1.eu.bt.net (166.49.211.253)  168.583 ms 234.537
ms  75.875 ms
11  166-49-211-241.eu.bt.net (166.49.211.241)  85.027 ms
     166-49-211-231.eu.bt.net (166.49.211.231)  169.837 ms  103.143 ms
12  core1-hu0-17-0-6.southbank.ukcore.bt.net (213.121.193.202) 66.045 ms
     core2-hu0-10-0-1.southbank.ukcore.bt.net (195.99.127.12) 109.886
ms  144.871 ms
13  * 195.99.125.143 (195.99.125.143)  162.059 ms  126.264 ms
14  * * *
15  * * *
16  [REDACTED].143.150.dyn.plus.net (150.143.[REDACTED])  215.653 ms 89.069 ms
66.194 ms
17  * * *
18  * * *
19  * * *
^C
bobpullen
Fixes: 327
@massive, have things broken again?
massive
@bobpullen Sorry for the late reply, everything appears to be working as it should, maybe the switching of your settings enabled things to re-propagate or reset.
bobpullen
Fixes: 327
Thanks for getting back to me. Very peculiar! The IP you were assigned after I reverted the change was similar to the one you had before too. Keep an eye on things and let me know if it happens again.
