Plusnet blocking Open VPN port 1194 TCP and UDP
FIXED- Subscribe to RSS Feed
- Re: Plusnet blocking Open VPN port 1194 TCP and UD...
- « Previous
- Next »
Re: Plusnet blocking Open VPN port 1194 TCP and UDP
21-09-2018 9:53 AM - edited 21-09-2018 9:53 AM
Right, I've reverted the change.
Although to be fair, it looks to me like UDP traffic is still getting to you
This is from a Vodafone connection:
$ traceroute -e -P UDP -p 1194 150.143.[REDACTED]
traceroute to 150.143.[REDACTED] (150.143.[REDACTED]), 64 hops max, 52 byte packets
1 192.168.43.46 (192.168.43.46) 3.361 ms 2.617 ms 1.734 ms
2 * * *
3 192.168.213.21 (192.168.213.21) 97.887 ms 156.679 ms 72.388 ms
4 192.168.213.22 (192.168.213.22) 69.346 ms 108.767 ms 116.252 ms
5 * * *
6 * * *
7 63.130.104.194 (63.130.104.194) 176.494 ms 105.906 ms 103.193 ms
8 ae13-100-xcr1.ltw.cw.net (195.2.23.77) 88.128 ms 87.059 ms 111.099 ms
9 ae32-xcr1.lns.cw.net (195.2.24.126) 140.652 ms 102.770 ms 144.044 ms
10 t2c3-ae1-0.uk-lon1.eu.bt.net (166.49.211.253) 168.583 ms 234.537
ms 75.875 ms
11 166-49-211-241.eu.bt.net (166.49.211.241) 85.027 ms
166-49-211-231.eu.bt.net (166.49.211.231) 169.837 ms 103.143 ms
12 core1-hu0-17-0-6.southbank.ukcore.bt.net (213.121.193.202) 66.045 ms
core2-hu0-10-0-1.southbank.ukcore.bt.net (195.99.127.12) 109.886
ms 144.871 ms
13 * 195.99.125.143 (195.99.125.143) 162.059 ms 126.264 ms
14 * * *
15 * * *
16 [REDACTED].143.150.dyn.plus.net (150.143.[REDACTED]) 215.653 ms 89.069 ms
66.194 ms
17 * * *
18 * * *
19 * * *
^C
21-09-2018 9:56 AM
@massive, have things broken again?
26-09-2018 2:41 PM - edited 26-09-2018 2:41 PM
@bobpullen Sorry for the late reply, everything appears to be working as it should, maybe the switching of your settings enabled things to re-propagate or reset.
27-09-2018 9:39 AM
Thanks for getting back to me. Very peculiar! The IP you were assigned after I reverted the change was similar to the one you had before too. Keep an eye on things and let me know if it happens again.
- « Previous
- Next »
