PlusNet Portal Failure - ongoing problem.
- PlusNet Portal Failure - ongoing problem.
Re: Trouble logging in
30-12-2007 10:35 AM
Will wait and try again later!
DJ
30-12-2007 11:08 AM
30-12-2007 11:22 AM
If it happens again look at the page source and go to the very bottom. You will find a line that looks like:
<!-- HmteacsWKdIUngC4bVdcEQ%3D%3D -->
That identifies the individual server.
If you post giving that line when it fails it could help identify the problem.
Re: PlusNet Portal failure?
30-12-2007 12:07 PM
I have merged three threads about issues logging into the Portal into one. All on the first page of the Community Support Board.
Please check for existing threads before creating new ones.
Jonathan
aka Chilly
30-12-2007 2:17 PM
I have previously reported a fault where I don't get incorrect message, just presented with the log in page, with my user & password boxes blank.
30-12-2007 4:12 PM
<!-- HmteacsWKdI5k3JRsvZC%2FQ%3D%3D -->
30-12-2007 5:01 PM
Update - seems to be back
30-12-2007 5:07 PM
Seems to fix it if you set autologin=OFF
Rely on your browser to store user/password.
30-12-2007 5:17 PM
It will help the CS teem.
30-12-2007 5:24 PM
<!-- I1BsQXdqvZuRgJTgZW8KdA%3D%3D --> failed
<!-- HmteacsWKdI5k3JRsvZC%2FQ%3D%3D --> worked
Ticket 23753464 raised
I presume everyone else having this problem has raised a ticket - these forums will not be being monitored that well over the holiday period.
30-12-2007 6:20 PM
Just been testing and and got it to fail 3 times. Then it logged me in and it's worked ever since
failed :
<!-- HmteacsWKdLeBh2TJD7uYw%3D%3D -->
worked:
Are you still having problems?
30-12-2007 6:40 PM
edit
just had four more goes - worked every time
30-12-2007 11:10 PM
Obviously cant raise a ticket about it if i cant log in 😛
30-12-2007 11:21 PM
31-12-2007 12:13 AM
Quote from: Midnight Moose can you copy the source code that is at the bottom of the page wen it next happens to you!
Hmm, i presume you mean this sort of thing <!-- HmteacsWKdLeBh2TJD7uYw%3D%3D --> (That's not mine!)
I don't see any when i try to log in. using Firefox or IE7.
