Please reset fibre connection
- Re: Please reset fibre connection
- « Previous
- 1
- 2
- Next »
28-04-2014 1:51 PM
This will only make things worse!
The ticket is only going in the direction of a BT visit together with a threat of a £60 charge. -- been there done that before, there's no point in more BT visits they have refused to replace the faulty cables in the past.
Please can someone from Plusnet say if it's possible to have my fibre connection reset or at least have the banded profile removed and interleaving enabled without the threat of a £60 charge.
28-04-2014 2:02 PM
I didn't realise that was possible for FTTC.
28-04-2014 2:18 PM
Profile Name 9M-18M Downstream, Interleaving Off - 0.128M-0.8M Upstream, Interleaving Off
Also my TG672 provides VDSL router stats, one of which is interleaving depth.
Now interleaving is disable I can see a increase in error in the routers stats, so I expect the next thing will be a even more restricted branded profile.
28-04-2014 2:23 PM
Quote from: npr ... there's no point in more BT visits they have refused to replace the faulty cables in the past.
Hi npr,
Are you stating here that BTOR admit that the cable is faulty, yet the still refuse to replace it?
If that is correct, then it is truly time that the CEO of PN went face to face with his BT counter-parts and sorted this nonsense out. There are at least 3 long running issues on the forum related to aluminium d-side cables which BTOR engineers state to be faulty / degraded which BTOR management refuse to rectify.
Come on Andy, "Do your customers proud and stop accepting this poor service from your supplier!".
At least you have the insight in being able to see the VDSL router stats, something the BT supplied modem seeks to hide... I wonder why?
28-04-2014 3:31 PM
BT have also said, through a plusnet ticket, that they will not be replacing the aluminium cable.
If only there was an alternative to BT. (sigh)
29-04-2014 9:40 PM
Quote from: npr
Can someone from Plusnet please comment.
30-04-2014 1:09 PM
This fibre connection is now syncing at:
down: 17999 mbps
Up: 0.491 mbps
Note:
The error levels on this connection are very low, it does not need to be restricted so much with this silly banded profile.
Quote Modem state: up
Up time (Days hh:mm:ss): 0 days, 3:03:20
xDSL Standard: ITU-T G.993.2
Channel Mode: Interleaved
Number of reset: 0
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 B203
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 17999 491
Attenuation [dB]: 26.1 7.7
Margins [dB]: 12.4 5.2
Output power [dBm]: 11.2 5.9
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 3.50 0.00
Delay [ms]: 8.00 0.00
Depth []: 577 0.00
R: 10 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 2
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 4 2
FEC: 14101 0
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 7 N/A
01-05-2014 11:13 AM
Quote from: npr
Quote from: npr
Please can someone from Plusnet say if it's possible to have my fibre connection reset or at least have the banded profile removed andinterleaving enabledwithout the threat of a £60 charge.
I give up.
01-05-2014 11:32 AM
Chris who deals with the really techy stuff has been off for a couple of days, so do not loose hope!
Kevin
01-05-2014 12:31 PM
Apologies for the delayed response - I've been away for a few days.
The £60 potential charge only applies if an engineer visits your premises and finds a fault to be with your equipment. The charge does not apply if you require your DLM to be reset. We have to give the potential charge statement to each customer before sending out an engineer.
Your upstream rate is too low given the downstream sync rate anyhow so it looks as though an engineer will need to get that sorted out for you. Assuming that nothing at the premises has changed, I can't see how or why you would be charged.
01-05-2014 2:00 PM
Are BT refusing to adjust this banded profile without a visit or have PN not asked?
I suspect the cause of the recent reduction in sync was due to interleaving being switched off -- can this be permanently enabled.
After all of the BT visits I had last year I don't see the need for any more, I really don't wish to be drawn into that pointless and frustrating exercise again. That is unless they change their minds about replacing the aluminium d-side.
01-05-2014 4:11 PM
It's not really a case of BT refusing to adjust the banded profile as the profile can't just be manually adjusted, at present, you would need a DLM Reset to be carried out or wait for DLM to change the banding accordingly. When we request a DLM Reset, it's part of an engineers visit - that's the only way we can attempt have it done unfortunately.
Interleaving can be left on permanently but it would require that you be moved onto the 'Stable' policy which may see a slight reduction in your sync rate but will keep Interleaving on. There isn't a facility for us or our suppliers to pick and choose, as you can on ADSL to enable/disable Interleaving or set it to Auto. DLM pretty much makes all the decisions for lines that require is automatically and most of the time, for good reason (not in all cases).
- « Previous
- 1
- 2
- Next »
