PhyR
- PhyR
PhyR
20-12-2010 6:31 PM
This appears to be a new impulse protection system from Broadcom that doesn't have the latency issues of interleaving while still providing impulse protection (well so they say), the headline blurb is:
As much as a ten times higher impulse noise resilience
Significantly lower residual BER or packet-loss
An extended network service area (higher rate, longer reach, lower delay)
Simplified network provisioning (no per user "tuning")
Firmware upgrade to central office and customer premise equipment
Transparency to network and upper layer applications (significantly reduces the burden on networks that use higher layer retransmission schemes for improving network efficiency)
Question is does PN / BT support this and is worth switching on?
Re: PhyR
21-12-2010 12:28 PM
Re: PhyR
21-12-2010 3:15 PM
More detail can be found on the Broadcom site.
Re: PhyR
21-12-2010 3:32 PM
Re: PhyR
21-12-2010 3:49 PM
Stallan/adiewoo - it might be worth enabling it and see what happens. If it has a negative effect then just switch it off again
Re: PhyR
22-12-2010 3:54 PM
Re: PhyR
16-08-2018 9:47 PM
Re: PhyR
17-08-2018 1:22 AM
Moderator's note:
Locked as the reply is to an 8-year-old thread
Forum Moderator and Customer
