Phone or BB fault
- Phone or BB fault
Re: Phone or BB fault
23-07-2012 3:13 PM
23-07-2012 3:59 PM
24-07-2012 10:22 AM
25-07-2012 11:56 AM
I am a little concerned now. Line has been completely stable, and there is no noise on the line whenever I check. Dont want to be wasting anyones time here, but will the BT chap have more in depth diagnostics, that may find an issue, that is currently not manifesting itself. its been dry here for the past 4 days, indeed, yesterday it was 25degrees here, which I think is having some effect in the lines stability. As an aside, with the stats as they are
ADSL Link Downstream Upstream
Connection Speed 7235 kbps 440 kbps
Line Attenuation 46.5 db 23.8 db
Noise Margin 8.0 db 16.7 db
What has been banded? I assume the upload has been capped with interleaving applied as well.
you can see my point, if you feel a BT engineer vist would not be helpful in the current circumstances, please let me know, and I can rearrange if the weather starts to deteriorate again.
Uptime is currently just over 25hrs.
Edit, forget that, I have just been outside, and its raining (god I wish the weather would make up its mind....) Checked the phone, and there is a mild degree of cracking on the line, but sync remains stable. Margin on the upstream is all over the place now, ranging from 7dB to 21dB. Downstream margin sat steadily at 8dB.
25-07-2012 1:38 PM
Happy to wait for you to do a bit more checking/testing if you'd rather be sure though, please let us know.
25-07-2012 9:30 PM
All stable again, as rain has stopped and weather brightened up. upstream sync now very stable.
Can I ask, for when we get things sorted out....
1.. What is the banding on the line, is it upstream or downstream or both, and whats it set to
2.. Is interleaving now on the upstream?
3.. Is the upstream now capped.
Reason for asking is, when we get back to normal, i think it would be good practice to leave interleaving on upstream permanently, 888kbps, is good enough.
Cheers
26-07-2012 9:45 AM
Your downstream and upstream is currently un-banded so your line should have the ability to reach its optimum speed, but obviously having this fault it is hampering that.
Interleaving is currently turned on, so is applicable to your downstream and upstream. Your upstream is uncapped.
Once the fault has been resolved then we can look at what is best profiles for your line to get the best performance out of it.
26-07-2012 11:18 AM
26-07-2012 11:39 AM
26-07-2012 11:55 AM
Lets see how the engineer vist goes... hope its raining ;), probably be blue sky, sunny day
Just stopped raining now, line sounds like an untuned radio
Cheers
26-07-2012 12:06 PM
Quote from: chrispurvey Good to see you've got the engineer booked, this will resolve it for you.
which has gone to
Quote from: chrispurvey ............. Hopefully the engineer will solve this and then you'll be back to your normal connection
26-07-2012 12:31 PM
which has gone to
Yeah. To be absolutely honest, i am not hopeful of a speedy resolution. Last fault I had took 8 engineer vists, and it was rather like this one. They cleaned up joints, virtually replaced all the cable inside house and the drop wire to the pole, which is outside next doors house. All ended up being a line card issue.... There is not much D side to check to be honest, i am only 400-500 feet from the Cab. Roll on fibre, although the blackburn exchange is never mentioned
Lets be optimistic eh!!!!
26-07-2012 1:10 PM
Unfortunately no mention of fibre yet, just have to keep checking up on it to see when it's coming to town.
30-07-2012 8:46 PM
Engineer came out this morning, decent friendly chap, who was quite knowledgable. Put his equipment onto my line, and after some checking said he had found a 'spike' 108m from the property. he also gave me some interesting info regards my line. The cable bunch from my house pole is a bundle of 20 copper pairs, which then connects to a 100 pair bundle of aluminium at the end of the estate, that goes direct to the Cab!! I had no idea my line had any aluminium in it at all. Anyhow, this is the only joint my 'D' side has until it gets to the cabinet. The 108m corresponded to the joint, which although he said looked fine, he remade it anyway. Did pair quality tests from the Cab, and from my house which all checked out fine. There was no more he could do, and the line was very quiet. Had to go out, so didnt get chance to reconnect up the router. When I did later in the day, First sync, I had dreadful upstream syncs (308kbps at a margin of 6dB!!). Checked the line and there was a bit of noise Rebooted router and got the following syncs
Down 6898 Mgn 9dB
Up 440 Mgn 25dB
no appreciable noise on the line now, just sounds a bit like when you put a seashell to your ear. Wonder if this was just a glitch with the first resync.......
Everything back to how it was, with a filtered faceplate back on etc.
I think we should leave things alone for the next few days, see what happens, but if its still the same, i have no idea what it could be. AFAIK, the engineer didnt check the 'E' side.
Chris, you said the upstream was uncapped, yet I thought a sync of 440 or 448 on ADSL2+ was indicative of a capped upstream....
31-07-2012 9:15 AM
I will also update your fault ticket, just so our faults team will be aware of the current state of your line.
Your line is currently showing as your upstream being uncapped although your speeds are not showing that. That shouldn't be a problem to resolve, but just want to check that your line is OK first.
