Phone knocks out broadband
- Phone knocks out broadband
02-04-2014 7:35 AM
Can anyone explain why when we use our phone, the broadband drops and we get a red light on router for internet.
Bought brand new phones yesterday and it's still happenening.
We have the 2 outlet BT Openreach MK2 box, with ADSL at top and phone in the middle.
Do I still need to put a filter on phone line or not?
Anyone else have same problem?
Cheers
Mick.
Re: Phone knocks out broadband
02-04-2014 8:16 AM
02-04-2014 8:54 AM
If you remove the front plate with the phone socket to just leave the ADSL working are all other telephone sockets in the house dead?
You should remove the front plate and the filter to expose the test socket and then try using a normal filter to see if the problem still occurs.
02-04-2014 9:35 AM
If you can try the steps jelv has mentioned above and if the issues still persists we'll be able to get this raised for you.
02-04-2014 9:41 AM
Quote from: jelv You should remove the front plate and the filter to expose the test socket and then try using a normal filter to see if the problem still occurs.
... and before fitting the "normal filter", plug in a corded phone and try a quiet line test (dial 17070 and select option 2) to check for noise.
I've had a fault in the last few days (which is being addressed) where a "1571" phone caused the connection to drop every 30 minutes when it grabbed the line to check for the intermittent dial tone as well as blocks of 4 or 5 resyncs occurring immediately sync occurs due to noise - so basically the same as you. Previously, I've had bad joints and an earth fault that exhibited such symptoms.
phil
02-04-2014 9:54 AM
Have tried as Jelv suggested, taken front off box, plugged into test socket and connected up using filter that came withh router and rang phone from my mobile, this is what happens;
Wi-fi light flashes green,
Broadband light flashes green,
Internet light goes out and then comes back on RED.
After a few minutes the Internet light goes to flashing green, then steady green.
At the moment broadband is steady green,
Internet is flashing green
Wi-fi is flashing green.
02-04-2014 10:56 AM
I've created a ticket on your account which you can view at https://portal.plus.net/wizard/?p=search which has all of the details on.
02-04-2014 11:46 AM
Will I get an email or something to let me know when it has been checked?, just so I know whether to look out for one or not.
Cheers
Mick.
02-04-2014 12:05 PM
02-04-2014 1:43 PM
I can see you've called in. My colleague tried to call you back but couldn't get through on your land line, it might be worth adding an additional contact number to your account - link.
07-04-2014 1:29 PM
Your Response
9:32pm, Saturday 5 Apr 2014
BT engineer called today 05/04/2014. He spent about 3 hrs trying to sort out problem, he saw how broadband dropped while using telephone. It is not a fault with our own equipment, but seems to be a line fault. He went outside to the pole outside our house and said that he cleaned connections and it seemed to help, but within 2 hours of him leaving I made a phone call and broadband dropped again, but this time it didn't come back on, so after about an hour I turned off router and turned back on which got our broadband back. So unfortunately we still have same problem plus the telephone line was extremely noisy during my call.
Your Response
2:48pm, Sunday 6 Apr 2014
4 times so far today 06-04-2014 our broadband has gone down, and I still believe that the problem is due to our line because everytime we get any wind blowing you can guarantee our broadband drops. This is now getting very frustrating as we are paying for something that we cannot use to full extent.
Regards
Mick.
07-04-2014 3:53 PM
07-04-2014 5:01 PM
Thanks for reply, but to update you, we have now booked to be connected to Fibre as our address is now eligible for connection. I have explained everything that is going on and was told that all faults
will be fixed by engineer on connection, but this won't be until 16th April.
Not sure if this makes any difference to my complaint, but today it has dropped several times again, but we expected this because there is a slight breeze.
Regards
Mick.
07-04-2014 5:14 PM
07-04-2014 5:17 PM
