Performance advice required
- Performance advice required
31-07-2007 12:42 PM
Being slightly ignorant on broadband speed issues, can I pose the following:
My line test says that I can support 4.5mbps, but I can rarely achieve 3. My average seems to be about 2.6. Shouldn't I be able to obtain better performance, or am I missing something?
I ran the following this morning:
![](http://www.speedtest.net/result/162948004.png)
Also I can't get the BT speedtester to marry up my phone no. with my login!
Message 1 of 8
(5,178 Views)
7 REPLIES 7
Re: Performance advice required
31-07-2007 12:49 PM
The line test from BT is purely an estimate based on information gathered at some point in the past about your line length and possibly quality. As telephone lines can deteriorate so can the speed achievable on them.
You may find this blog by James useful on understanding MaxDSL
Message 2 of 8
(2,035 Views)
31-07-2007 12:53 PM
As usual Chris has sniped in before me with a quick reply![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Your router is currently connected to the exchange at 3328Kbps and as such is profiled at 2500Kbps by BT and ourselves. You need to attain synchronisation speeds (and maintain them) at 3424kbps in order to get put onto the 3000Kbps profile.
Message 3 of 8
(2,035 Views)
31-07-2007 1:45 PM
Thanks for that guys.
I've read the blog etc. and - being ignorant - what else can I do to improve this sync speed to the 3424kbps required, apart from being connected to the main input socket and making sure that all my sockets have filters on them and keeping other telephony connections to a minimum?
Message 4 of 8
(2,035 Views)
31-07-2007 1:48 PM
That is possibly the maximum your line can support, if you can post your line stats we should be able to see the attenuation and SNR which can give us an idea of how long your line is and the speeds it can support.
Message 5 of 8
(2,035 Views)
31-07-2007 3:47 PM
Now I'm getting lost with 'line stats'. I followed the link, and am using a Belkin F5D 7632; I can get to the status page, but can't see how I go about getting line stats from there. Anyone any ideas please?
Message 6 of 8
(2,035 Views)
31-07-2007 3:54 PM
Downstream:
Attenuation: 60dB
SNR: 9dB
Sync: 3328Kbps
Upstream:
Attenuation: 21dB
SNR: 21dB
Sync: 448Kbps
It's mainly the downstream information that's important. Your downstream attenuation gives a good gauge as to how line your line is. At 60dB, it's nearing the limits of the distance that broadband can support.
However, given that the SNR figure is relatively low at 9dB, it would suggest that the quality of your line is pretty good, especially for the length that it has to travel.
I really wouldn't expect any improvement on 2500Kbps. You would be very fortunate to get 3000Kbps.
Attenuation: 60dB
SNR: 9dB
Sync: 3328Kbps
Upstream:
Attenuation: 21dB
SNR: 21dB
Sync: 448Kbps
Message 7 of 8
(2,035 Views)
31-07-2007 4:05 PM
Quote from: basils57 Now I'm getting lost with 'line stats'. I followed the link, and am using a Belkin F5D 7632; I can get to the status page, but can't see how I go about getting line stats from there. Anyone any ideas please?
http://www.kitz.co.uk/adsl/frogstats.htm#anchor3 should help
Message 8 of 8
(2,035 Views)
