Password change
james1972
Password change
Good afternoon, can anybody please advice how to change the wifi password on my hub two router?
Thanks in advance
4 REPLIES 4
Fixes: 479
Re: Password change
@james1972  Welcome to the Plusnet Community Fora.
Log in to your hub here http://192.168.1.254/wifi.htm.  Input the Admin password from the label on the hub pull out tab (if asked) Change the Security Password and save.
james1972
Re: Password change
@Baldrick1 Thank you so much for the swift reply 👏👏👏
Fixes: 479
Re: Password change
@james1972
I assumed that the link I gave would put you straight into the Advanced Settings Page. If you land on the home page simply select Advanced Settings, enter the admin password then select wireless. Don't forget to Save the new setting.
If you ever forget the new password simply factory reset the hub and it will restore the default one.
james1972
Re: Password change
@Baldrick1 I wont be changing it until possibly Wednesday next week, but once I have I will definitely press the fixed button once it's done.
