Anyone switched from Now broadband (copper) to PN Fiber?
smartroad
As the subject said, has anyone switched from NOW  to PN Fiber? I am getting confused, as Now is on Openreach PN should be able to cancel it but also it is copper and I have read that I'd have to tell them. But then when do I cancel, I need to give 30 days notice, but I need an engineer to come out to inspect, then later to install so when do tell them the last date?
I am so confused!!
5 REPLIES 5
RobPN
Fixes: 13
Re: Anyone switched from Now broadband (copper) to PN Fiber?
@smartroad wrote:
I am so confused!!
So am I!
Fixes: 344
Me too, @RobPN . Wonder if the OP actually wants FTTP, in which case, some the question(?) makes garbled sense.
Fixes: 542
If its an FTTP order, then the order process will ask to confirm the existing services should be cancelled. In which case PLusnet will place a 'change of ownership cease' transfer order to complete when the FTTP is installed.
Fixes: 98
@smartroad
Can you post a screen image of the the results from the following (hiding your details but including any narrative below the results window).
Fixes: 344
Thanks, @MisterW . Hopefully, that will answer the OP, and it clarifies things for me, too.😀
