PPP Auth Failure
phillipstanton
PPP Auth Failure
I have the dreaded ppp authentication failure. Came home from work to find the router failing to connect. When logged into the router (tg582n) it keeps try and getting authentication fail. My username/password are (I think) what was set up at the start but it won't allow me to connect. I've also tried my pn [email protected] but not sure what password would be. I'm at a loss. Any advice gratefully received.
9 REPLIES 9
bobpullen
Fixes: 330
Re: PPP Auth Failure
I believe we did have some authentication troubles yesterday/last night (IMT-1969), which should now be resolved. Are you still experiencing difficulties?
phillipstanton
Hi, unfortunately, yes I am still unable to connect. "connection could not be established: disconnected by user."
MatthewWheeler
Fixes: 503
Sorry to hear that.
From what we can see you're trying to connect with the wrong password.
It may be worth resetting the router using the pinhole on the back or alternatively resetting your password here then updating it in your router.
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
phillipstanton
Thanks Matthew, I've reset my password but won't be able do that on my router until I get home (had to go in to a local office to work today, grrrr). I assume that's fairly straight forward once logged in to the router? And would the username be 'username' @dslplus.net?
pjmarsh
Fixes: 24
Almost.  it would be [email protected]
phillipstanton
Soooo close. Thank you.
adamwalker
Fixes: 223
Glad to see you got back online phillipstanton let us know if there's any further issues.
 Adam Walker
phillipstanton
Unfortunately, far from sorted Adam, as it seems that every day my router now resets to a random account username. It does seem to auto update when restated but I can't access the router via my usual wired connection (don't know why) which requires me to turn it off and on again physically.
adamwalker
Fixes: 223
That's odd, what's the username that you're seeing?
Can you let me know if you're using the original Technicolor router we provided?
 Adam Walker
