Online Tracker and Dial Up
- Online Tracker and Dial Up
Re: Online Tracker and Dial Up
04-09-2007 1:51 PM
Quote from: orbrey Unfortunately there is, and having checked BTs system there are no notes on the order stating why this is delayed. Our provisioning team will be chasing this up with BT but this can't be done until the order is 24 hours late. As such you should get a more detailed update tomorrow morning.
Sorry for the hassle,
It would appear, according to email that i am now active, will have to wait till i get home to confirm though.
Again i would like to say thanks for the swift response.
04-09-2007 7:36 PM
05-09-2007 1:35 PM
1) your username and password from your previous ISP
2) username: bt_test@startup_domain password: test
3) username: bt_test_user@plusdsl.net password: test
Please let us know if any of these are successful, thanks (bear in mind that the latter 2 will show a connection in your ADSL hardware but you will not be able to browse any web pages). We suspect that BT have not changed the realm over on the RAS, which will be proved if you can connect on your old login but not on the plusdsl.net one.
Hope this helps, please let us know.
05-09-2007 8:00 PM
I even recieved a new router from yourselfs, which won't even allow me to enter username and password becasue it won't sync. I ran the diagnostics on it, results are as follow:
Test the connection to your local network
Test your Ethernet Connection: PASS
Test your Wireless Connection: PASS
Test the connection to your ADSL service provider
Test ADSL Synchronization: PASS
Test ATM OAM F5 segment ping: FAIL
Test ATM OAM F5 end-to-end ping: FAIL
Test the connection to your Internet service provider
Test PPP server connection: FAIL
Test authentication with ISP: N/A
Test the assigned IP address: N/A
Ping default gateway: N/A
I tried in my old faithful Netgear and it didnt work, same problem.
Any ideas?
Ticket number: ID: 22767188 btw
06-09-2007 10:14 AM
I've just replied to your ticket, just asking to confirm your power status. Let me know and I'll get onto raising with BT.
06-09-2007 10:27 AM
06-09-2007 10:38 AM
I've raised your fault to BT and replied to your ticket.
06-09-2007 10:46 AM
Quote from: James Hi there,
Ok. thank you.
06-09-2007 8:50 PM
Log on to the router to enter my username@plusdsl.net logins and they go though...it thinks about it..then say it cant connect and then starts blinking again. So i dont know if BT were doing something?
What are the chances of me getting connected by Monday? Three months on Dial up is starting to be a pain in the bum...
Personally i think it is something to do with Sky broadband when i cancelled them. I was told by a BT engineer that they put things on the line to allow me to get above 8mb and get the 16mb service, so i wonder if thats on there still, and is making my line unstable?
Really need to get this sorted ASAP.
07-09-2007 9:32 AM
Could you possibly confirm whether or not you have power turned on your modem/router?
07-09-2007 9:37 AM
07-09-2007 10:05 AM
I've run a line test and I'm still seeing you as not gaining synchronisation, so I'll pass it back to them and ask them to run further diagnostics.
07-09-2007 10:23 AM
Quote from: James Right. BT made a change to your SNR and appplied interleaving on your line at roughly 7pm last night.
Ok thanks.
07-09-2007 9:47 PM
10-10-2007 6:54 AM
i had simular problems due to router falling off the wagon when it rebooted, lastnight i waited 59 minutes for it to connect so i could use some overnight usage
I've now got fastpath on my line and it's very good.
Moderators note by James_H : Removed full quote of preeding post - it is not needed and is a breach of the link:rules
