Novice question re speed
- Re: Novice question re speed
10-11-2007 12:50 PM
I am on PN Premier Option 1 - it shows I can get up to 1.5M. BT shows my exchange will handle up to 2M. I have achieved 1 to 1.2 in past.
But recently I have got only 0.4 to 0.5
Is there something I am doing wrong? I have a Netgear DG834GT wireless router
Message 1 of 6
(1,709 Views)
5 REPLIES 5
10-11-2007 3:29 PM
To eliminate the wireless side of things, what ping times do you get if you ping your router?
Are you using the b, g or b&g setting on your router?
Message 2 of 6
(528 Views)
10-11-2007 3:31 PM
assuming you are on MaxDSL then you may have had a low resynch recently.
To give us a better idea what is happening can you post the stats from your router
This shows you how to get them http://www.kitz.co.uk/adsl/frogstats.htm#anchor26b
Message 3 of 6
(528 Views)
10-11-2007 4:57 PM
Quote from: axisofevil To eliminate the wireless side of things, what ping times do you get if you ping your router?
Errrr. sorry but how do I ping my router?
I am using b&g
(a real noviceI'm afriad - but thanks for you help)
Message 4 of 6
(528 Views)
10-11-2007 4:59 PM
Quote from: Oldjim assuming you are on MaxDSL then you may have had a low resynch recently.
Here are the stats (JPEG attached )
System Up Time 45:10:42
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 290705 441005 0 242 3111 45:10:07
LAN 10M/100M 669133 593170 0 3215 641 45:10:40
WLAN 11M/54M 70602 168412 0 308 85 45:10:38
ADSL Link Downstream Upstream
Connection Speed 2112 kbps 448 kbps
Line Attenuation 60.0 db 31.5 db
Noise Margin 7.3 db 13.0 db
Message 5 of 6
(528 Views)
10-11-2007 9:14 PM
If you maintain those stats you should get speeds up to 1500kbps so lets check the stable rate.
Can you go to here https://portal.plus.net/my.html?action=data_transfer_speed and see what that says. Also try the BTSpeedtest http://www.speedtester.bt.com/ and see what that says. You may need to have several goes to get it to respond as it is a bit flaky in the evening.
The IP Rate on this test should match the one from PlusNet.
However looking at your figures I would think that you are pushing things to maintain that connection speed with a 60dB attenuation.
After doing the above tests is it possible to connect your router to the master socket behind the main socket and report back the results. This is a small picture of it.
Message 6 of 6
(528 Views)
