Not what I had hoped for by a mile
amutimer
Guys,
I am not sure this is the right place, but I want to express that I am pretty unhappy with what I get from Plusnet.
.1. It took months to connect me. That's right, months.
2. Once I got the service - fibre - it was actually exactly the same speed as my old non-fibre bradband
3. I complainmed and Plusnet did a reset and it crawled up to the minimum of my contract. It *never* has gone into the "expected" range - ever.
4. The page load speed is now the worst I have ever had since I left dial-up behind.
5. And then I find I can get full fibre from Vodafone...for less money....
6. And then I find Plusnet don't do full fibre to this address. And yes, I checked, Vodafone's offer is real and not an error.
I have hated, and am still hating, my experience with Plusnet
Adrian
25 REPLIES 25
Fixes: 334
Re: Not what I had hoped for by a mile
@amutimer , taking your points in order:
1. There are no details on here of your connection journey, so I can't comment.
2.That can happen if the automatic systems don't do as expected.
3 & 4. We need some solid data to determine what is going off here.
5 & 6.Maybe Voda are using an altnet?
IF you want help, and are prepared to help us help you, just say so.
Fixes: 457
@amutimer
From your question here https://community.plus.net/t5/My-Order/Any-Pre-instllation-work-I-can-do/m-p/1898885#M26103 and the responses that you received it should have been clear that the concensus was that you were referring to a new Full Fibre (FTTP) contract with Plusnet. Maybe you misunderstood the difference between Full Fibre and FTTC Fibre/Fibre Extra services?
Either way, you are no doubt locked into a contract with Plusnet, If you want help with getting the best out of this then as @jab1 suggests, if you can engage with us by explaining the full story maybe we can help/advise.
Fixes: 334
@Baldrick1 That never went very far, and to be honest I disregarded it due to the lack of response.
amutimer
What is the solid data you need?
A
Fixes: 334
Assuming, as it now appears, that you are on an FTTC and not FTTP connection:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Fixes: 457
@amutimer
A screenshot of the results from entering your phone number here after obscuring your phone number would also be helpful. https://www.broadbandchecker.btwholesale.com/#/ADSL
Fixes: 334
@Baldrick1 That is covered by the 'BT Broadband' link above. 😁
amutimer
BT speed with cable .jpgBT speed with wifi.jpgBT Test.jpgOokla speed with cable.jpgHere areOokla speed with wifi.jpg
Image 1 is BT speed using a cable
Image 2 is BT speed using wifi
Image 3 is BT wholesale
Image 4 Ookla speed using cable
image 5 is Ookla using wifi
The noise test produced silence.
I can't produce the router page becuase I a using a different router than the one supplied.
What seems to emerge is that Ookla always reports a lower speed figure than BT, and that cable makes big difference.
On the BT wholesale page it says FTTP not available. So I checked the Vodafone website and my adress says full fibre *is* available. So I phoned and queried all this, and they checked again, and they confirmed they could offer full fibre. Can anyone make sense of this?
A
Fixes: 334
Which Router are you using - whichever it is, there should be a screen which gives the data required - the below image gives an idea of what we need. I'm out for a while now, but will comment further when I return.
Fixes: 526
yes, Vodafone can offer fttp using the City Fibre network.
amutimer
Right. Should I take it that my Plusnet connection is not through City Fibre then? I had the idea that the City Fibre was the only fibre option in this street. They put it in a few months ago. If I am not using City Fibre's network whose am I using?
A
Fixes: 526
You don't have full fibre (FTTP)  you have FTTC ( fibre to the cabinet ) . This is provided by Openreach''s network. Openreach have not installed full fibre in your area yet.
amutimer
HI,
I think I  must be working with some kind of false assumption.
Up until a few months ago we could not get fibre of any kind here. Then City Fibre dug up the street and laid fibre cable. After that we had fibre offers from lots of providers.
City Fibre suggested we use Vodafone, who I was using already, but I did not do that because the Plusnet offer was advertised as faster and cheaper. My assumption when I changed was that Plusnet must be using City Fibres cable because that was the only fibre available. Was I wrong?
I begin to fear I am now stuck with Plusnet who are not using the cable down our street. Stuck for 17 months...
A
jgb
Champion
Fixes: 22
Plusnet are part of the BT group and will thus only provide a service over the Openreach network and so they will not use the City Fibre network.
