Not getting what I’m paying for
Liam99
Decided to upgrade my wifi as the previous pusnet deal was terrible now this one I’m paying the minimum is meant to be 500mps but don’t don’t it has ever seen 400
4 REPLIES 4
Fixes: 384
Re: Not getting what I’m paying for
Is it just possible your own equipment could be the limiting factor here? Have you tried a direct PPOE connection to the ONT?
Liam99
I’m using the equipment they supplied to use tried to sort it with plusnet via there text method they supposably reset it but nothing has changed
@Liam99
Guaranteed  speeds would be for a wired connection to your Hub Two, some wifi devices are not capable of a connection of 500Mbps.
Fixes: 246
There’s vey little chance that the uplink is slower than the provided package.
There are though lots of possibilities that your kit does not have the power to use all of that bandwidth alone. How are you testing? Over WiFi or Ethernet?
WiFi will max out circa 400mbps.
